FWIW, needle threaders are not good on most machines. They are very delicate and are easily bent or damaged.
For manual threading, it helps to lick your finger and then swipe it across the back of the needle eye. Take the end of the thread and start slightly above the needle eye and slide it down toward the eye and the thread will usually slip right through the eye.
SOURCE: Singer Athena automatic needle threader does not work.
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
SOURCE: Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
