Question about Sony Office Equipment & Supplies
I have a sony snap lab in need a of a printer head does anyone have an old machine in good working order willing to sell? Or know where to get replacement parts?
Posted by Karen Lancaster on
5 Related Answers
Anonymous
  • 919 Answers
SOURCE: Hand microphone for DT 100 does not work. Need replacement mic
MR-9 Microphone for DT-1000
The MR-9 Microphone allows direct dictating to the DT-1000 Transcriber and also permits you to control the playback functions remotely. Remote playback functions include Listen, Fast Forward, Rewind, and Stop. Cord extends to approximately 6 feet.
http://www.olympusamerica.com/cpg_section/cpg_audio_acc.asp?val1=1&accessory=76
Posted on Jan 30, 2009
Anonymous
  • 152 Answers
SOURCE: Left Screen Hinge on Thinkpad T42 is broken
Have you checked eBay? A lot of people sell replacement parts there for computers.
Please remember to rate my solutions! Thanks
Posted on Feb 05, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Battery cover for BLACK Sony T70 is broken.
Battery Compartment with lock of DSC-T70 is single part and can be order under following part number..
X-2186-609-1 ASSY, BTH (B) (BLACK)
I'm afraid I do not have info about parts shops in UK so please check with nearest Sony Service Center for that part.
Thanks.
Below image of DSC-T70 will give you an idea for required part..
Posted on Jul 16, 2009
domotek
Tommy
  • 591 Answers
SOURCE: I broke the left hinge on my HP OfficeJet J6480.
Sorry but you need to replace it with genuine HP part, call HP directly or a local HP partner repair shop...
Posted on Jul 10, 2011
Don Buffkin
  • 95 Answers
this is the address for HP customer support, (Replacement parts)
You should be able to get your hinge here
If this was helpful please rate it and supply testimony
Thank you
Don
How do I change the lid on a Cabrio washer (model # WTW7800XW2)?
If you lift the lid up and go to the base you will see 2 torx head screws on each side remove them lid will slide up an off small tip when trying to remove screws if they are tight or stubborn stop they have a tendency to rust in place you may snap off trying to remove bad design if this happens order new screws 4 and hinges they are different order left and right
Feb 12, 2015 | Whirlpool Washing Machines
How do i clean the hp printer's in order to get a clean and darker print?
Print quality depends on cartridge health condition only, especially in inkjet printers.*Print head clogging: Usually white horizontal lines in print outs due to print head nozzles are clogged. Printer it self having self cleaning mechanism to clean the nozzles while printing & powering on..And "clean nozzles" option also designed in printer drivers for cleaning. And last option is manual cleaning. Alcohol is good solvent & best for cleaning the nozzles,use cotton or ear buds to swab on the surface of the nozzles with alcohol gently.. You will get good quality print outs if cartridges are in good condition..(see the snap shots)Other parts to clean: Encoder,disc encoder, service station & rollers needs to clean periodically to avoid malfunctions & paper jams.* Encoder's malfunctions: If any vertical or horizontal crooked print outs observed, clean both encoders needs to clean.. (see snap shot for encoders)*Service station malfunctions: If any carriage jams observed in service station, remove & clean it ..(see the snap shot)*Rollers malfunctions: If media is not picking up properly it causes jamming error,clean or replace the rollers..
Dec 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
CAN THE SNAP LAB DO CHRISTMAS CARDS (SLIM LINE) 4 X 8?
Yes, but you will need to upgrade the printer's version to the latest version. Go to http://www.kobisonline.com/Sony-SnapLab-UPCR10L-Snap-Lab-Digital-Photo-Printer-UP-CR10L_p_9.html for the firmware upgrade link
Dec 08, 2010 | Sony SnapLab UP-CR10L Digital Photo...
MY SONY SNAP LAB will not power up. I changed the
Sounds like your SnapLab's power supply is dead. You will have to send to repair, or order the part and replace yourself (if you think you are qualified to do that yourself...)
May 06, 2010 | Sony SnapLab UP-CR10L Digital Photo...
Brother MFC 465CN Printer, NO YELLOW
Hi There
A good old clean out some times works do this 2 or 3 times.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
May 06, 2010 | Brother Multi-Function Center MFC-240C...
Printer error
The printer is probably damaged, so, call Sony tech at 1-800-883-6817 x21 . If they will not be able to trouble shoot the problem, they will direct you to the repair facility. You have 1 year warranty on this printer if purchased from an authorized Sony dealer.
Jacob
www.kobis.com
Nov 10, 2008 | Sony SnapLab UP-CR10L Digital Photo...
Error when printer is turned on
It could be that someone has tried to update the firmware and has
interrupted the process before it had finished.If this has not been the
case you could try updating the firmware go to Sony's website or do a search on the internet for Snaplab firmware update and you will see Sony's information. Download the firmware relervant to your machine going by its serial number on the back .Save this to your hardrive then
connect your printer and follow their instructions but do not switch it of halfway through as this can ruin the machine permanantly.
It could be a damaged ribbon sensor although fairly cheap to buy if you
can get one is a big job to fit. We have had faulty ribbons that have caused a similar problem so try a different batch of ribbon.
Aug 30, 2008 | Sony SnapLab UP-CR10L Digital Photo...
Does anyone know how to remove print head?
The print head nozzles is clogged but good. None of the cleaning the machine can do will clear it. Been there and trid that. Doesn't work. The clogs need to be dissolved with a specialty clog buster and probably will need to soak at least 24 hours, maybe more. Don't deep clean any more as you will put so much in in the absorbent blotters on the inside of the printer that you will trigger an error code and not be able to print until the absorbant pads are replaced by a service tech for about $100.
Aug 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Problem printing
Probably means the print head is jammed and can't slide freely on the track. Try unplugging the printer and *gently* sliding the head/cartidge toward the center. Then inspect the cartridge path to see if you can find an obstruction. It may help to remove the case (it should snap off) unless that makes you nervous. Lots of good suggestions at . Good luck!
Sep 09, 2007 | Canon PIXMA MP780 All-In-One InkJet...
104 people viewed this question
Top Sony Office Equipment & Supplies Experts
matt martin
matt martin
Paul Bade
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
