SOURCE: electric motor 9 Volt 2400 rpm
Try here:
http://www.pltv.org.uk/bush.htm
http://www.wiltsgrove.co.uk/category.php?page=1
http://www.albaplc.com/html/Brands/Alba%20Radio%20LP.htm#
Phone Number:0208 787 3100
SOURCE: PORTABLE DVD PLAYER NOT SPINNING DISCS AND SAYING NO DISC
When it is region lock it will say it on the display, if the player is not reading any disk, it is more likely a lens problem, see below:
Try first using a lens cleaner disk, like the ones here.
If
that does not work, the unit must be disassembled, and lense cleaned
with q tips and isopropyl alcohol or cleaning solution. See below:
How to Clean the Laser Pickup Lens on your DVD Player
How to safely clean a DVD lens?
Clean DVD lens, or replace player?
Clean CD or DVD ROM lens with a brush?
Cleaning your DVD drive
How to clean a DVD player
How do I clean my DVD player optical lens isoproponol alcohol
SOURCE: dvd player wont read dvds
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
SOURCE: I have a durabrand 7inch portable DVD player.
if you bought this unit from walmart you could call there customer service and they may be able to help you find a supplier no to see if these parts are still available Durabrand Technical Support, Parts and Accessories
http://1800customersupport.com/
Also the support division of these companies:
Audiovox
Durabrand
ILO
Kawasaki
Lextron
Magnavox
RCA
Trutech
V7
Venturer
The actual manufacturer:
Alco Electronics
Hong Kong
Company : Alco International Ltd.
Address : 11/F, Zung Fu Industrial Building, 1067 King's Road, Quarry Bay, Hong Kong.
Telephone : (852) 2880 0698
Fax : (852) 2880 0858
E-mail : [email protected]
Website : http://www.alco.com.hk
EUROPE
Company : Venturer Electronics Europe Ltd.
Address : Unit D, Bourne Park, Cores End Road, Bourne End, Bucks SL8 5LS, United Kingdom.
Telephone : (44 1628) 527 757
Fax : (44 1628) 527 794
http://www.alco.com.hk/main/
SOURCE: cordless trimmer 7inch cut model 51556 serial
Go here....you can download the manual....It's free!
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
