Question about ZTE Cell Phones
My zte phone needs a puk code it was locked - ZTE Cell Phones
Posted by Christopher... on
UnlockNinja
    Master:
  • ZTE Master
  • 462 Answers
PUK lock (Personal Unlocking Key). It's a security feature on most mobile devices that protects your SIM card data and unique for SIM card.
May I suggest that you contact your sim network provider as they are the only one who can provide you the PUK codes. Once you done the PUK unlocking you can use the unlock code.
Here is the NCK unlock code for ZTE
Official Zte IMEI Permanent Unlock Important Select the Current Network...
my zte phone needs a puk code it was locked - how-to-unlock-zte-phone-xmihpvsyiwup0zhnfhcff41q-5-0.jpg
Posted on Jan 31, 2018
5 Related Answers
zaids
Zaid Anarwala
  • 457 Answers
SOURCE: puk code for ZTE MOBILE PHONE
you can contact your service provider for the puk code
otherwiae no one can help you
Posted on Sep 29, 2008
Anonymous
  • 3 Answers
SOURCE: UNLOCK A TELSTRA LOCKED ZTE F156
unfortunately you cant...you have to take it in and have it reset..if your service provide it..if you have a home phone call your service pro and they can asst you..if you have patients..lol
Posted on Nov 10, 2008
djonghs
Hiong Sip Djong
  • 12 Answers
SOURCE: sim card phone locked message need puk code to unlock
PUK stand for Personal Unblocking Key, this is the key that could only generated by your phone service provide. Usually, your 1st PUK come with your phone card, please all the documents you received when subscribe to your provider. If not available, the only think to do is go to your nearest service provider customers service office and they will help to generate a new PUK to unblock your phone.
Posted on Dec 11, 2008
nonontech
Lebanon Raingam
  • 4737 Answers
SOURCE: i need to unlock the PUK code on my samsung phone.
It's not the problem with your phone, contact the customer care of your service provider (network operator), and tell them your problem, they will give you the number instantly. If you enter wrong/random numbers several times, your sim card will be unusable. Good luck
Posted on May 24, 2010
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: need puk code for locked LG KE850prada phone
If you need the PUK ( Personal Unblocking Key ) for your phone, you will have to contact your mobile phone service provider.
PUK code is related to the SIM card you are using. So, kindly call the Customer support of your mobile service provider and they will provide you with the PUK code.
Also, entering a wrong PUK code ten times in a row disables the SIM card permanently. So, please be careful while entering the PUK code.
Hope this solves your problem. Thanks for using FixYa.
Posted on May 25, 2010
I need my puk code for my zte z833 phone
May I suggest that you contact your sim network provider as they are the only one who can provide you the PUK codes. Once you done the PUK unlocking you can unlock you phone for all network
with unlockninja
Please help I need zte z987 puk lock and help unlock network or rooting
Here is the unlock code solution for your zte z987
https://www.unlockninja.com/unlock-zte+z987
now once you get the unlock code you need to follow the steps below to use this
How to Unlock a ZTE Phone 1.Insert SIM card from a source different than your original Service Provider
(i.e. if you have a Rogers phone, use a non-Rogers SIM card),
2.Phone will ask you to enter Sim unlock pin (NCK code or PUK Code )
3.Enter unlock code
4.Phone will be unlocked
I need to unlock sim on zte n9100
Hi Irene, If you've locked your cell phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code..... If you lock your cell phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
By not knowing SIM unlock pin I ****** up my zte xmax plus ,now I need too enter puk unlock pin how do I fix it
Hi Jenn, It's not that bad.... If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
If you lock your phone again some time in the future and you're still with the same service provider you can use that same Puk code.. CHEERS..
I've got a ZTE straight talk phone and my PUK code has showed up and should have 8 numbers or more please help
Hi Leslie, If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
Sim lock zte v793
Hi Azrul, If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
1helpful
Unlock code for zte t815
Hi if you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
Need free codes for zte
Unlock code for zte z936 L straight talk
Hi Steven, If you've locked your phone through entering an incorrect pin number 3 times then you need a Puk code, Ring your service provider and they will give you the FREE Puk code.....
Cell Phones Logo
Top ZTE Cell Phones Experts
Paul Carew
nexrad_chris
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
