Ordered the part but dont know how to install it Dishwasher tech said it was simple?
Check youtybe Dishwasher Repair - Replacing the Drain Hose (Frigidaire Part # 154753201)
Dishwasher Repair Replacing the Drain Hose Frigidaire Part 154753201...
Testimonial: "thank you for this, however it is not helpful. We are replacing the sump hose. not the drain hose."
SOURCE: Kenmore dishwasher 665.1671590
Your inlet hose probably came loose on the left side of the dishwasher. If you pull the d/w out 6 inch. or so you will see the s-shaped hose going to the inlet port on the tub. Make sure it's not pinched or leaking..Catriver
SOURCE: I have this code error
That will be a main control board. Also if you have a touch pad replace that also. If its more than three years do not repair but replace.
SOURCE: frigidaire gallery series FDB125ORES1 wash
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
SOURCE: error code HO on frigidaire gallery series dishwasher
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature
SOURCE: Fridgidaire Gallery Series Dishwasher Leaks from bottom
Hi, wre
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Hello - I suggest verifying that there is enough water pressure coming into the unit. Do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies.
thank you, but this is not helpful. We are replacing the sump hose. not the drain hose.
Let me have the model number of DW
FGID2474QF1B
This not you model but steps should be closehttps://www.youtube.com/watch?v=bSjdNIE7PtQ
