Having issues researching this model #, but front loaders fron LG have two springs and either 2 or 3 shock absorbers to dampen vibrations. Take top off and check that the springs are in place and not broken. If good then from the back or from underneath, check to make sure the shocks look good, connected, etc. if no obvious issues I would replace all the shocks because if springs are unbroken and in place, they are rarely an issue.. also, do a spin cycle without any clothes and see if unit spins without issues. It should. If it doesn't you may have a broken spyder that holds drum to hub. Bigger issue, hard to replace but possible. Good luck.
SOURCE: LG inverter Direct Drive 7kg
UE is the error the washer will display if it detects an unbalanced load. If your LG washer was a model that contained the Ball sensor, it could be a bad part.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
SOURCE: Lg front loader wd11020d water leaking from back of machine. Hoses not leaking filter clear.
MAY BE WATER SEAL HAS GONE,,ITS SOULD BE REPLACE WITH 02 BEARINGS,,,
Thank you so much. I'm very grateful for your help.
