Question about Ultra Computers & Internet
Bought Aspire V-5 ultra thin that has password that on hard drive that stops me from getting into BIOS is there a way round it? I didnt get any manuals or anything
Posted by Connie Parrott on
Vebble
    Master:
  • Ultra Master
  • 395 Answers
You would have to dismantle the laptop and remove the BIOS battery for 5 mins then re-insert it to reset the BIOS to factory setting. I found this reset option (picture below) online but have never tried it ..............
bought Aspire V-5 ultra thin that has password tha - capture-e4a2v32stn4jawoct3vivien-1-0.jpg
Posted on Jan 28, 2018
  • Connie Parrott
    Connie Parrott Jan 31, 2018
    He was very helpful I got mixed up on numbers sry my bad
5 Related Answers
Anonymous
  • 27 Answers
SOURCE: thin white line (hoz) across screen (gets on my freaking nerves)
A Few things you can try,
Updateing Graphics Drivers, Check Connections, Adjust resolution and refresh rate, Connect to another monitor to rule out GPU and Software issues.
Posted on Dec 13, 2007
jvernice
Joseph Vernice
  • 63 Answers
SOURCE: Acer Aspire One has Hard drive Password frozen
There should not be a password set in the BIOS unless you set it up with one. You can clear the BIOS to BRAND NEW state. Acer can guide you through this if it is under warranty. If it is not, write back and I will help you do this.
Posted on Jul 28, 2009
John P Griffin
  • 89 Answers
SOURCE: acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Posted on Aug 02, 2009
Anonymous
  • 2600 Answers
SOURCE: Reset Bios Password for Acer Aspire 7720Z Notebook - Ron M.
Here is the link to your service manual, when you click on it and bring it up...it is a pdf file so you'll need adobe or another pdf reader, go to page 40, that is the directions for resetting and removing the BIOS/hard drive password. Good luck
http://tim.id.au/laptops/acer/aspire%207730%207730g.pdf
Posted on Sep 27, 2009
Anonymous
  • 31 Answers
SOURCE: How to crack /unlock the password set on SATA HDD port 0 in CMOS on Acer Aspire-5050
Cheap solution available at http://www.acersnoop.co.cc
Posted on Jan 26, 2010
I forgot my hdd password and want to deactivate computrance in bios
I take it that you've forgot your bios password.. Take off your side cover of PC (check this through your manual if you have it) and look for a round shiny battery. near there you will see 'clr cmos'. Next to that you may see 3 pins with 1 jumper. Disconnect power source. Take the jumper off it's present 2 contacts the 'jump the centre on and the one that was open. Count 5 secs and reverse back to original 2 jumpers. Your bios will tell you ( when you reboot) that cmos needs setting. Your password has now gone from your bios. I you have a password on your hard-drive try downloading Hirens Boot Disk 15. Boot from the CD and there are a myriad of repair & fixes that come there which will help you Hiren Pankaj Homepage www hiren info
Oct 18, 2014 | Hitachi HDD 500GB HD 0A53487 25 SATA 3G...
I need to turn off the hard drive password on my accer aspire 5532
You can download a password recover program from the net and run it, it will either tell you your password or reset if for you. Once you are in your system you can go into your security settings for the main user and disable the password protection.
Sep 27, 2012 | Acer Aspire 5532-5535
I am having trouble with my acer aspire 5050, that it wouldn`t start because i've forgot the bios password to login to my system device... could you help me, how to reset my bios password...
Use Unlock Acer Bios Recovery Service to get your bios password reset with a bios master password they calculate just like Acer Support. These guys are pros at clearing bios passwords and hard drive password on laptops. Reset your bios password for only $20 and they guarantee it to work.
Sep 16, 2011 | Acer Aspire 5050-3242 Notebook
I just bought a acer aspire 5315 from a yard sale and was told the hard drive was bad. i went and bought a wd scorpio blue 250gb sata hard drive. after installing it i put in my windows xp disk to format...
i not sure but ill try to help all bios password user
enter wrong password 3 time if u get a code send me that code ill send u master password if i could not help dont angry let me know ill find another way.. Thanks
Sep 27, 2010 | Acer Aspire 5315 Notebook
Forgot my BIOS Password for Acer 5630 and I NEED HELP!!
open all the compartments on the bottom. It will not be in with the battery but it might be with the hard drive or the memory. when you find it, it will be obvioius. It might be under the keyboard and the keyboard might be easy to remove. look for latches just above the F keys. That is where my compaq keyboard latches are located. I didnt check the WWW for your model and I didnt look at my little Acer ... in the basement.
Im sorry I was so hard on you before - it has been a ruff day here at the milleraba household. water is trying (and succedding) to get into my freshly carpeted basement. I really shouldnt be fooling around here - I should be tending to the basement. I did manage to get a hole in the concrete and a pump installed ...not perfect but will have to do till morning...
Thanks for posting your question at FixYa.com
Dec 28, 2009 | Acer Aspire 5630 Notebook
How do I get round a safe boot screen which
Best way would be to give the computer back to the owner and ask them to enter the password... If you have no idea what the password is, I can only assume that this does not belong to you.
If you bought it this way, sorry to say, the only way to get around that is to format the hard drive and reinstall the OS, as SafeBoot is a form of Whole Hard Drive Encryption.
You may need to enter the BIOS and set the machine to boot from the optical drive first so that you can boot the recovery/OS disc, this is, if the boot function key (F12) has been disabled. Try pressing F12 at the POST screen (Dell logo) and see if the Boot menu comes up. If it does, you can boot the disc from there, without messing with the BIOS settings.
Dec 12, 2009 | Dell Computers & Internet
Forgot my password in cmos harddisk
The hard disk password is setup using the BIOS configuration, this password is stored on the hard disk and there are no backdoor passwords you can use except the password you created and if you know this password then you can remove it permanently using the BIOS configuration. Moving this hard drive into another laptop will not work either, it won't allow access to this hard disk.
Your only option is to purchase a new hard drive to replace the one with the password.
If you also created a BIOS password, you need this password to get into the BIOS configuration.
All these passwords are created by users to prevent unauthorized access into the laptop and hard disk.
Apr 24, 2009 | Acer Aspire 5602WLMi (LX.AB10J.002) PC...
Acer aspire 5315-2698 want to restore to like ner . restall from
If it has a hard drive password, you must remove it before you will be able to restore your OS.
Mar 15, 2009 | Acer Aspire 5315 Notebook
Boot problem
There are three possible options ranging from free (if you are not afraid to open your laptop, locate and remove the bios battery) to $170 (for a new hard drive and a cloning kit).
Option 1: Here is a copy of an email from Acer Support:
Thank you for contacting Acer America. I apologize for the delay in responding to your inquiry. In order to have the BIOS or hard disk password removed (This include any biometric security), the notebook will need to come in to our repair depot for password removal. This service is not covered by warranty and unfortunately there is no other recourse to remove a BIOS or HDD password from the notebook. The flat fee for BIOS password removal is $100.00 US dollars plus tax. If it is a BIOS or HDD password and you would like us to service it for you, please contact our telephone technical support line at 1-800-816-2237. Hours of operation are 7am-9pm CST Monday-Friday and 8am-5pm CST Saturday and Sunday, excluding holidays.
Option 2: Resetting an Acer BIOS Password Using Hardware.
If you cannot boot the Acer and don't want to send your computer back to Acer for an unknown amount of time, you can try to reset the BIOS password via hardware.
Tech FAQ Forum members have reported that they were able to remove their Acer BIOS passwords by simply opening their notebooks and removing the CMOS batteries for 30 minutes.
Once your BIOS password is removed, you will need to press the <F2> key during POST (Power On Self Test) to enter the Acer BIOS setup.
Option 3: Possibly resetting BIOS Password using Hard Drive Upgrade Kit and a new Hard Drive.
A colegue told me that he used a hard drive upgrade kit and during the cloning process the hard drive password was erased. He can not recall providing the password when he booted from the bootable cloning CD provided with the Kit and when he replaced the hard drive with the cloned one and botted the laptop, the hard drive password was gone! He had to go into bios to manually enter a new hard drive password.
The kit he used was about $50 - APRICORN EZ-UP-UNIVERSAL 2.5" USB 2.0 Hard Drive Upgrade Kit - Retail. He paid for a bigger hard drive separately, but he just needed bigger hard drive (and found out about the password erasure by accident).
Jan 06, 2009 | Acer Aspire 3680 Laptop
Hard drive boot up password
-Boot system to BIOS
-Load bios DEFAULT
-If no..go Contact manufacturer and get the default hdd password.
Oct 05, 2008 | Acer Aspire 5315 Notebook
Computers & Internet Logo
59 people viewed this question
Top Ultra Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Vebble
Are you an Ultra Computer and Internet Expert? Answer questions, earn points and help others
