Check your guitar with another amp, or a different guitar with this one with no effects pedals, etc, to narrow it down to just the amp. At that point, try reversing the polarity. If none of the above helps, you may indeed have a bad ground somewhere and you'll need a tech to follow it to the source.
Hi there,I have the same problem with my flexwave 120. I opened the amp to measure several capacitors on the small effect circuit board. If one of this capaciters have internal short circuit, wich will effect the others causing effects to fail. I removed them one by one to find possible short circuit. All capacitors were ok. I think the problem is in the processor wich is to diffucult to replace. I think it's easier to replace the effects circuit board. But where do we find this board??
It is likely that there is a failure of one of the amps in the unit. It could be a cracked circuit board, bad solder, bad volume control, or a bad compnent in the power amp section for one side. HOWEVER something does NOT compute here as you can't connect more than one speaker to a 15 Watt Crate amp... Maybe you have two of these amps.
I don't know how you know the tubes are good... It is possible they are microphonic... try tapping them with a pencil (only need to worry about the smaller ones).
Beyond this look for cracked circuit board or bad solder... especially near the control pot leads. This is a common problem. Look for cracks near the booard mounting points.
This is a warm up issue and can probably best be found by using circuit cooler on suspected components.
Other possible problems may be a bad solder joint or cracked circuit board.
Candle the board with a bright light to look for cracks.
Bad solder joints take experience to spot, but pay particular attention where panel mounted volume controls solder to the circuit board. Looking for the little ring around the solder menicus takes a sharp eye and good lighting. Resolder any suspected bad joints.
its a crate. 60% of all crate amplifiers go back on defects. take the top screws out and slide out the chasis, look at the fuse and determine if its toast. if the fuse is good, get a new amp. if the fuse is bad replace it and you should be good. the circuit board will have the correct fuse to be used printed on the board. yostamplifier.com
you have either a failing fuse or a failing power transformer. take out the screws on the top of the amp, leave the handle in tact and pull out the chasis. look at your fuse to see if it is in its holder correctly, and see if the fuse is burnt. the correct fuse values will be printed on the circuit board. if the fuse looks good then, it may be the power tranny going south.
