Question about Maytag Refrigerators
From the drawing on your model, it looks like you may have to take out the top drawer and possibly the case for the drawer. Sometimes it is behind a light shield (usually an opaque piece of plastic) although I do not see one listed for this model. The correct # for the bulb is WPA3073101 which is a 25 watt bulb but I am sure you can find an "or equivalent" that would work just fine. It could be clear or have a blue coating to make the light more natural.
Posted on Jan 28, 2018
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
SOURCE: ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Posted on Oct 18, 2008
SOURCE: Kenmore bottom freezer model freezes veggies in the crisper
i never go by that / just hold my finger over the air port and move it till i feel move air or less to set it the way i need it ,,, less air puts less air into crisper to cut down on freezing
Posted on Nov 26, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
SOURCE: Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Posted on Jul 10, 2010
Jan 02, 2016 | Electrolux Refrigerators
Jul 26, 2012 | Fisher and Paykel Dishwashers
Mar 24, 2011 | Refrigerators
Feb 07, 2011 | Maytag MSD2758GEW
Sep 02, 2010 | Maytag MZD2766GES Side by Side...
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Oct 06, 2009 | Refrigerators
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
