Washing Machines Logo
S
Simon Nicholls Posted on Jan 27, 2018
I have no hot water on my hot point washing machine Aquarius wmpf 742?
How do you remove the front panel of a Hotpoint Aquarius WMPF 762?
From the diagrams on line, I think you have to remove the bottom panel to get at the screws in the bottom. The top appears to be able to be pried up on the front side. That's as far as I can help you.
1helpful
Hot point Aquarius machine. Lock light flashing red but won't reset.
could be ther is still water in the machine which is why the door is still locked still wast pipe blocked unplug it fo a while 30 min
Washer will not spin it start to but barley moves
my hotpoint wmpf-742 machine,been told bearings have gone,just need to know,if it has a sealed back,if it has,also been told to scrap it??
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
2answers
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Hot point HVL-241 first edition 1400 washing machine
Just leave that concrete block there, it is to prevent your tub from taking off skywards.
2answers
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Top Washing Machines Experts
john h
