Question about Belkin Computers & Internet
I need to retrieve the password for my belkin router, I got a need phone and I need to set it up.
Posted by Sebrina Washington on
  • Mark Magill
    Mark Magill Jan 27, 2018
    Hi Sebrina, I want to help you with your question, but I need more information - please provide the exact model number of the router. Also, do you have a LOT of things running on the router that would be a pain to set up all over again? If not, its very easy to reset the router, wiping the old (secure) password. Belkin routers often have model number such as N 150, N6000, and so on.
5 Related Answers
hyperpeeps
SOURCE: password for belkin router
Dude if u forgot! Set it to its factory settings. First remove all cords and grap a paper clip. Put the paper clip in the reset spot. plug the power cord in it while holding the clip in. hold the clip in for 20 seconds. Then it will reset to factory and you can have a blank pasword and reset it to whatever you want.
Posted on Feb 25, 2008
Anonymous
  • 115 Answers
SOURCE: lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Posted on Jan 25, 2009
fredtmccoyjr
Fred McCoy
  • 380 Answers
SOURCE: i need to password secure my belkin wireless router
This is not a difficult task, but if it is done incorrectly, your router will need to be reset. So, let's go ahead and get a long, thin pin, or sewing needle,or something that will reach into the recessed reset button hole, because we may need it a few times.
I too have a belkin wireless router, so I know a little about them. However, I dont know your exact model or firmware/software programming, so a true "step by step" is not possible from me. Contact Belkin for operator assistance. Here are some General things you will need to do.
1. Reset the router. Go ahead and do that now. that way, we have a clean slate. Press the reset button and allow the router to restart.
2. Make sure the Modem is connected to the INTERNET port on the router. You should see 5 ports on the router, 1 2 3 4 are ONLY FOR COMPUTERS. if it has a number do not put anything on it unless its a computer, or xbox or playstation game console. The MODEM, the DSL, or w/e will NEVER go to ports 1 2 3 or 4. Now, make sure that your MAIN computer is HARD WIRED to PORT 1 on the router. You DO NOT EVER make wireless router adjustments over a wireless connection. You must hard wire to the router.
3. LOG IN to the router. The router has a built in website that allows you to operate it. on a belkin router, that website is located at the Default Gateway address. (ok, you probably dont know what that means, but thats ok, we can still do this). MOST belkins have a default gateway address of 192.168.2.1. So, you will open your internet explorer and go to the ADDRESS BAR. There, you will type http://192.168.2.1 and press GO. You SHOULD see a page that says Belkin.
4. BY DEFAULT there is no username or password. so if you are asked to login, leave them blank and hit submit.
5. this is where it can get hairy, but, its nothing the reset button cannot fix. You will be looking for a few things First thing to do is click login, of course, so you can log in. remember, its default, so its blank.
6. Now that youre logged in, look for WIRELESS and click there. If you are using wireless machines, make sure wireless is ENABLED. It should be, by default, but, lets take a look and make sure, just to be safe.
7. Next, were gonna set the SSID to your last name, (or your dogs name or your nickname or favorite place). The SSID is default to Belkin, but if 10 ppl around you ALL have belkin routers, you'd have no way of knowing which one is yours, So, the SSID boradcasts a unique name to identify YOUR network. Changing the word Belkin to "Scoobydoo" would mean that you would be the Scoobydoo network, and anytime anyone is in range of your router, they would see "scoobydoo" as a site. You also want to ENABLE Essid broadcast, and unless you have an older wireless B card, set to Wireless G only. (g is more secure). Everything else, leave at the current setting.
8. Now we are going to SECURE your wireless so that when people see "scoobydoo" they wont be able to JOIN it, unless they have your KEY. Click Security. We are going to create a key. With Wireless G you can use a 26 character key, which is a set of HEXIDECIMAL characters. HEX is 0-9 and A-F. No letter higher than F will occur in Hex. So, click WEP (wpa is usually more secure, but I prefer WEP). Choose WEP and Choose 128 bit encryption. Next, use a passphrase, (this will generate a key for you). Say you put "shaggy" as the passphrase. Based on that word, a 26 character key would be generated. Now, This is important, WRITE THAT KEY DOWN EXACTLY AS ITS SHOWN. Without that key, no one can access your router on wireless. Also, dont forget to press "Apply Changes". Once you apply those changes, all your wireless connections will be lost. You will now have to go to each wireless computer, and apply the key to each one so they can access the router.
Posted on Jul 21, 2009
Mohamed Omran
  • 2567 Answers
SOURCE: Speedstream router - password retrieval
Try using the following default user name & password:
Username : admin
Password : hagpolm1
Posted on Jul 26, 2009
garethmt
Gareth Tomlinson
  • 116 Answers
SOURCE: I need to retrieve my password on the Speedstream 6520 Router.
not possible to retrieve a password! that's why they are secure... if you have your ISP ADSL setup details you can reset the router to factory default and reprogram it from scratch, or call their help desk BEFORE you do it and ask them to email you the connection details before you start. then WRITE the password on a label and stick it to the router.
Posted on Mar 26, 2010
May i know how to change password
  1. Click on the Belkin Router Manager icon (right-click for Windows) to open the menu. If your router did not come with the Router Manager software open its web interface by entering the address 192.168.2.1 and skip to Step 4.
  2. On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
  3. Click to open the Belkin Router Setup page on your Web browser. 4.You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button. 5.Scroll down and click the Utilities > System Settings link from the page menu on the left-hand side. 6.On the Utilities > System Settings page, you can retrieve an existing password or create a new password.
Hi my wireless router is not working..i need security key for that..how can i get that key
Welcome to FixYa! The security key for the Belkin router is what they also called the Pre-Shared Key, it maybe in the form of word, phrase or series of letters and numbers. The key must be between 8 and 63 characters long and can include spaces and symbols, or 64 Hex (0-F) only. Each client that connects to the network must use the same key (Pre-Shared Key).
1. Click on the green Belkin Router Manager icon (right-click for Windows) to open the menu, or type 192.168.2.1 into a web browser.
2.On the Belkin Router Manager menu, scroll up to Router Settings and highlight.
3.Click to open the Belkin Router Setup page on your Web browser.
4. You must log in with a password to make changes to your Router's settings. If you have not yet set a custom up a password, leave this field blank and click the "Submit" button.
5. Click the Wireless > Security link from the page menu on the left-hand side.
6. On the Wireless > Security page, you can retrieve your password(s) from the fields to the right of the Pre-shared Key (PSK) > entry.
7. Uncheck the Obscure PSK box to view and retrieve your password(s).
8. Re-check the Obscure PSK box to obscure your password(s).
Hope this information will help. Thank you for using FixYa!
Retrieve a password
There is not way to retrieve a lost password on a router, you will need to reset the router and set it up again. If you need help doing that, you will need to supply me with the make/model of the router.
I have a belkin wmp11 but lost the code to put it on a new computer how do i get a code
Uncheck the obsucre psk
3helpful
How can I unlock my Belkin G wireless router so that I can connect my wii to it?
click here and read my various tips to get a clear idea about your question...
4answers
Lost codes
On the back of your router there is a reset button, hold it down for 3o seconds or so, this will reset the router back to factory settings, the default user name and password would be admin, note that sometimes with the belkin you only need the user name and not the password. Usually you need admin/admin though.
The default IP address to access the router when its reset is 192.168.2.1
Hope that helps
1helpful
Yeah hey...belkin wireless router password reset
What is the brand of the router your using? This information will be from the router that you have. Use a wired connection from the router,check your default gateway (ipconfig) and type that numbers in your address bar. You will be able to access your set-up page, look for wireless tab and look for wireless security. You will see there your WEP key.
2answers
Connecting second laptop to my Belkin Wireless G router
I don't know the model of your router this would be very helpful. Most routers have a reset button on the back of the router. This will reset your router back to factory default settings.This will reset the pasword to default usually "admin". You will need to set up your router all over again. Let me know the model and I can send you a link for installation of your router.
Computers & Internet Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Resolution IT Dubai
Resolution IT Dubai
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
