Question about Puma Watches
How to set time for puma 805 watch ? - Puma Watches
5 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: I have the Puma Men's
Try to visit www.theusermanualsite.com
Posted on Dec 21, 2008
Carole Bern
SOURCE: setting the time for the puma sirius
Finally got it! Take a sharp ball-point pen and push it into the hole/bitton on the lower left side of the face. When I first tried it a zillion times, I could not get anything to happen. Then I handed it to my husband, and he said that you have to push it in with a little bit of force (more than mine, anyway) and the "setup" mode appeared. After that first time, it doesn't have to be pushed as hard!
Posted on Jan 01, 2009
mcdevito75
Michael C. De Vito
  • 1970 Answers
SOURCE: I cannot figure out how to set the time on my Puma watch.
mcdevito75 here, You can try www.puma.com They have an overseas number but also the option to find a Puma retailer in your area.
Posted on Jul 13, 2010
belltech
  • 4 Answers
SOURCE: Howdo I set time on a puma watch pu910222003
Setting the time on the PU910222003 Puma ladies watch.
The process is actually less complicated than you would think.
First, a couple things you need to know and remember.
1. The watch has a safety feature which requires you to press the touch button on the right side of the watch before you can do anything as far as touching and changing anything. If it did not, every time you accidentally touched the dial something would change.
2. Touch means you are touching the dial and the (stones or outer edge)
To change the time, day, date etc, on your PU910222003 you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Now you are ready to change stuff.
Touch the dial and the little what looks like bling at the bottom of the watch. You need to be touching the watch dial and these stones at the same time to do anything we are about to do.
While touching and holding the bottom of the dial you may see the back light turn on.
That is actually how you do that.
By continuing to touch and hold the bottom of the dial, you will then see the word hold at the top and then the hour of the time flash.
To increment the time or decrement the time, touch the right side of the dial or the left side of the dial. When you have arrived at the current hour, touch the hour at the top again and the minutes will begin to flash.
Continue to set all settings in this manner until you are satisfied. Touching the top to move to the next setting and right or left of dial to go up or down.
When you are done. Touch the bottom of the dial to exit this setting mode.
Day to day use,
Touch the time at the top of the dial to scroll through the time, chrono, alarm etc. To see time if the screen saver is on, touch the left side of the dial. Touching this repeatedly will also scroll through all the phrases programmed into the watch.
While touching and holding the bottom of the dial you will see the back light turn on.
Cool feature,
This watch actually has two displayable times you can use if you travel often to a second time zone. Press the touch button on the side and touch the right side of the dial. Touching it for a second or two will display the time of the second time zone. Touching and holding for a couple more seconds will cause the T2 on the display of the left side of the watch to flash and eventually switch to the second time. I am thinking that touching the bottom of the watch while displaying the second time should allow you to set this time also.
Posted on Mar 07, 2011
belltech
  • 4 Answers
SOURCE: i have Puma-Time touch screen
Dont have that particular watch, but see if this works.
The process may be less complicated than you would think.
To change the time, day, date etc, on your watch you must first press the touch button on the side. The word touch will light up (display) inside the watch on the right side of the dial.
Day to day use,
Cool feature,
How to set time in puma digital watvh
https://brand.puma.com/time/support
www.youtube.com/watch?v=PxcHizUdJk8
Jun 17, 2014 | Puma PL1050
I just got this puma watch TOP FLUCTUATION PU104210037891945098568. HAVING PROBLEM SETTING TIME Details.
I didn't find the PU model # you listed.
Try finding your instructions with the manuals found here:
http://www.puma.com/time/support#manuals
Dec 28, 2011 | Watches
Jul 13, 2010 | Puma Active Collection Fluctuation...
I have bought a puma watch> I don't know the number, but it's a metal, square yellow gold-looking watch. I can't set the time. Is it possible to send me a manual. Thank you for that.
mcdevito75 here, Best Bet, visit a small watch repair shop in your area to order another manual, or visit Puma online at Puma.com. It"s possible someone here at fixya has a manual, but I doubt it. Check with the repair service directory here at fixya, bottom of this page, click on repair service directory then watches see if someone can order the manual for you.
Jun 29, 2010 | Puma Flow Analog W ( Pink/White) Watch for...
PUMA FLUX watch - reset time
Press and hold the button on the upper left until it displays "HOLD" then wait 'til the light goes out, you'll see the hour-digit blinking, set the hour you want, then for the minutes, press the lower left button. Press and hold the upper left button to set the desired time.
May 02, 2010 | Puma Digital Alarm Chromograph...
Setting the time for the puma sirius
Aug 04, 2008 | Puma Bracelets PU103SLA0051500 Watch
Watches Logo
424 people viewed this question
Top Puma Watches Experts
Janelle Schoonover
Janelle Schoonover
ray gallant
Tom Chichester
Are you a Puma Watch Expert? Answer questions, earn points and help others
