Question about Dual Audio Players & Recorders
Where to obtain user guide for marantz sd-160 dual deck cassette player
Posted by EDWARD NIEBAUER on
Jean DeLauche
  • Dual Master
  • 2,911 Answers
Hello, Edward -
I have only been able to find Service Manuals for the Marantz SD-160 dual deck cassette player for sale.
I was unable to find the operating manual for the vintage cassette player / recorder on the Marantz website.
However, if you have not yet already done so, I suggest you contact Marantz Support, either via phone or email, and ask if there is a copy of the operating manual for the SD-160 in the company archives and if they could provide you (sell you) a photocopy or scanned PDF version of the manual. This is the link to the Marantz Support page:
https://marantz.custhelp.com/app/answers/detail/a_id/104/kw/manual/related/1
If that option doesn't work out, Option 2 is to find one or more online sellers (eBay, Craigslist, Amazon, etc.) of the model of cassette player / recorder and see if they mention the operating / owner's manual in the product sales information. If they don't mention a manual, I suggest contacting the seller/s and asking if they have the manual.
If you find an online seller with the manual, ask if he / she would either photocopy the manual for scan it as a PDF document and sell it to you.
Best wishes.
Posted on Jan 26, 2018
Vladimir Frolov
  • Dual Master
  • 2,075 Answers
Why do you need it?
5 Related Answers
Anonymous
  • 98 Answers
SOURCE: Cassette Player
  • very easy.. if your motor 12 v or 6 volts...for 12 volts motor buy an ic "kia 7812 this parts is voltage regulator with 12 volts 1a output..7806 this parts is volt.reg with volts 1a output..7803 3 volts output etc. etc.
  • input 1st terminal
  • ground mid terminal
  • output 3rt terminal
same a transistor.
Posted on Feb 05, 2008
petraman7
Scott Frye
  • 1175 Answers
SOURCE: Door won't open
It might be a model that has a special IC that allows the door to open and close.
You'll need to take the case off.
try hifiengine.com...that site may have the service manual.
Kirk out
Posted on May 05, 2008
Rob Galayda
  • 54 Answers
SOURCE: Cassette door won't open
IF it is a deck with " soft touch " controls, that is, you arent using the old press hard down " piano key" style, but NOT a pure touch switch activation, then chances are either the drive belt has slipped, the belt broke, or the motor died. If this is the case ( soft touch = yes ), then unplug the unit, pop the cover off. You should be able to see the mechanism. When you view the mechanism from the front ( the side you normally see when using the deck ), the shiny little silver post that pulls the tape through during normal play will turn counter colckwise ( the shiny post runs against a rubber wheel ( the pinch roller )). What you should try is , with the unit unplugged and the cover off, if you can get your fingers to the deck in question, find the flywheel, should be a larger disk with a belt around it. Carefully spin the flywheel with your finger so that it turns counter clockwise, if you were looking from the front of the unit. This should cycle the deck through its cycle until you hear a click. Try to open the door. If the door doesnt open, press the stop button WHILE turning the flywheel again. This should drop the head assy and disengage the door lock mechanism. Remember, make sure the deck is unplugged, and BE GENTLE. you may feel a little resistance as you turn the flywheel. A little is OK, just be careful. If the flywheel comes to a hard stop when you are turning it, then something is jammed and you need to take it to a repair shop. Good luck...Rob. In the future, please specify a make and model so we can better help you . Thanks !!!
Posted on May 09, 2008
Anonymous
SOURCE: Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Posted on Jul 11, 2008
xalint1
xalint1
  • 152 Answers
SOURCE: Sony Stereo System
Your in luck there is a user guide online that has all you need to know.Here is the link
Posted on Jul 30, 2008
Connect Yamaha stereo cassette player KX 380 to htr-6025 receiver
HI RICHARD
To connect your cassette player to your receiver, you may have to use an RCA-type of plug (you know, the red & white plugs on both ends.
BOB (June 23rd '12 3:45am)
Apr 20, 2012 | Yamaha KX 390 Stereo Cassette Deck Single...
User manual for sony tc-wr635s download
Have you tried visiting the Sony web site, Cathy? I'm sure they have a web site.
Jan 31, 2012 | Sony CASSETTE DECK Single Dual Cassette...
I need the instruction manual for a Marantz audio cassette deck model no. SD 60.
Let me have your e-mail if you still need it. I have what is termed the "User Guide"
Nov 04, 2009 | Marantz Audio Players & Recorders
HOW DO I GET A MORANTZ RECORDER DIAGRAM
if paper, photocopy it, if cassette, use a cassette dubber. if you don't have one and need one, try phoning the company, or ebay or google it. www.hifiengine.com has a buch of free manuals and other paraphanalia. you will need to sign up but it's free and they don't need much information.
Mar 18, 2009 | Marantz PMD101 PORTABLE PROFESSIONAL...
133 people viewed this question
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
