SOURCE: instuction for canon camera SX20 IS
You can download for free the instruction manual directly from Canon here.
SOURCE: replacing battery cover door on Canon AL-1
Very easy to replace door. Remove base plate (3 screws). Remove 1 screw found in battery compartment. Lift corner of battery compartment (right where you took the screw out) up about 1/4". No more or you will break the opposite corner. Use a piece of picture hanging wire and push the hinge pin from the outside toward the inside until you can grab it with tweezers and pull it right out. Rest is simple.
