Question about Xerox WorkCentre 7556/P Copier
I bought a used 7525 Xerox. Wont print now. Screen reads Activation Code Attempts Exceeded. The maximum number of Activation Code attempts has been exceeded and activation code entry is now locked.
Posted by Raphael Khumalo on
  • 4 more comments
  • Priti Mane Jan 26, 2018
    The previous owner has set activation code check if you can get the code if unable to then reset the Xerox..use the following steps
    1- enter diagnostic mode >> hold 0 10s then press start >> password 6789
    2- tab on Adjustments then tab on dc301 NVM initialization >> choose copier >> selest all >> then initialize.
    3- tab on call closeout then exit & reboot.
    4- after the macthine turned on you find it in a non customer mode.
    5- again enter diagnostic mode again >> hold 0 10s then press start >> password 6789
    6- tab on Adjustments then tab on dc131 NVM Read/Write > enter 616-014 >> change the value to 2
    7- again tab on call closeout then exit & reboot.
    8- while the machine is turning choose customer then follow the setup as you want till reach to lock or unlock tools >> choose unlock tools.
    9- you will never need the admin password again also on the web page.
  • Raphael Khumalo
    Raphael Khumalo Jan 26, 2018
    Thank you for your detailed reply. The statement on the screen says"You will have another chance to enter a valid activation code in 20 hours" If I do not make the interventions you suggest now and and wait for the 20 hours, what will happen then?
    Try to contact the old owner see if you can get the code if not then try the reset and check.
  • Raphael Khumalo
    Thanks well appreciated
  • Anonymous Feb 03, 2018
    Hi Priti, your solution worked until the 1st February when the machine started demanding the Activation Code. When we went over the same process as we had done before, the machine did not respond. We are temporarily operating as Guests. A bit of background, is that when we received the machine and turned it on, there was a flushing light and the local Xerox technician said the battery was low and needs changing which we have not done. Your expert opinion will be appreciated.
  • Priti Mane Feb 04, 2018
    Happy to know the solution worked, I would advise to change the battery as advised by the local tech and check.
Priti Mane
    Habit-Forming:
  • 32 Answers
Posted on Jan 26, 2018
Testimonial: "Thank you Priti, well appreciated. You have not answered my second question though. There is a light that flashes at first, latter it remains on throughout. The message on cable connections is not there. Thanks"
    What message do you get need more details please.
Tareq Bin Mostaq
    Habit-Forming:
  • 199 Answers
Now you press default code 1111
Posted on Feb 03, 2018
docukaaf
    Habit-Forming:
  • 38 Answers
You have to reinstall the software whit the usb firmware to reset the bloked machinne
Posted on Jan 31, 2018
5 Related Answers
Anonymous
  • 214 Answers
SOURCE: Ph locked/disabled.
please give yr mobile Model No, IMEI No. and yr correct service provider name
Posted on Sep 08, 2008
VinayT
Vinay Tevatia
  • 1884 Answers
SOURCE: Multiple attempts of wrong entry of Lock code
Gone is gone. Too late and sorry.
Posted on Aug 10, 2009
pawanverma8
Pavan Verma
  • 112 Answers
SOURCE: error "You have exceeded the number of invalid
you have tried a lot of time with wrong password. Try to reset your password then tried it again with right password. If its noit work your account is deactivated by Facebook.
Posted on Aug 10, 2010
Audioaholic
Brad B
  • 376 Answers
SOURCE: I used driver detective 6.6.0.15
this key is for a certain number of uses, and was used up, or was a fake one.
Posted on Jan 07, 2011
Fazlul azim
SOURCE: I cannot register my fring
I have exceeded allowed number of attempts to register my fring account.My mobile number is +8801817069310
email [email protected]
Posted on Apr 23, 2013
Mar 09, 2013 | Cell Phones
Oven has f90 error code and door stays locked cannot get oven top door
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]@@@
Aug 27, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I get a code f90 when trying to either lock the oven door or attempting to clean the oven
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jun 26, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Code f90 indicated
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%#
May 26, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
F93 error code
unplug the range.
wait 1 minute.
wait 2 minutes.
Apr 24, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
F93 code (door not locking) tried to 'reprogram' by leaving unplugged for an hour, worsened the situation. Now when repowering, it immediately attempts to lock the door, obviously unsuccessfully and throws...
unplug the range.
wait 1 minute.
wait 2 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&^%$
Mar 16, 2010 | Frigidaire 30" Self-Cleaning Slide-In...
What does the errror code F90 mean?
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 18, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
F93 fault code
unplug the range.
wait 1 minute.
wait 2 minutes.
Oct 04, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kenmore gas range trouble
unplug the range.
wait 1 minute.
wait 2 minutes.
Nov 20, 2007 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Xerox WorkCentre 7556/P Copier Logo
442 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
