Did you resolve your issue? Mine is doing the same .doesn't matter how big or small the button is the buttonhole is always 8mm as you say
It could be that 8mm is the limit for the buttonhole foot. You can try making buttonholes manually with the sewing machine. Not really difficult. Just need to be careful marking the buttonhole and stitching. Recommend practicing on scrap fabric before trying it on the project.
How to Make Buttonhole on Your Sewing Machine Sew4Home (several methods)
Creating Buttonhole Using Sewing Machine
how to sew buttonhole without buttonhole foot Google Search
SOURCE: One step button Hole V for Singer Sewing Machine
Hi, I had the same problem, but I finally found my manual. The solution is that you have to use the presser foot for buttonholes but the most important part is that you have to lower the buttonholer lever. It is located right next to the needle to the left. It is a metal lever with a little square white plastic end. You need to pull that down in order the the buttonhole feature to work. My button was too big for the buttonhole presser foot, so I had to use the regular presser foot, but hit the buttonhole lever with my had to make it go up or down.
SOURCE: Attaching fit button-hole foot?
Just pull down on the original metal foot. It will snap off and then you can snap on the button hole foot. Good luck!
Trudy
SOURCE: How do you sew button holes?
I am assuming that you have marked where you want the button hole to be.
Here is the link to the manual for the 5050.
446_5040_5050[1].pdf
The instructions for making a buttonhole are on page 36
SOURCE: I can''t remember the steps
you can download a manual for the Activa 145 here, buttonholing steps would probably be very similar for your model
http://www.bernina.com.au/webautor-data/888/0305295204_0303_a135-a145_EN.pdf
It says you sew one bar, then press the reverse button and the automatic function then sews the bar tacs, other side, bar tack and finishes.
SOURCE: Can I use a 1-step button hole foot on a brother LS14 sewing machine?
It would probably be easiest and fastest to contact your local Brother dealer. If your machine can use the unit, you can probably buy it directly from the dealer.
