Question about Samsung Cell Phones
My Samsung Gear S Smart watch keeps dropping the Bluetooth connection to my Samsung Note 3 phone. When connected it works perfectly then after a few minutes I get the message Bluetooth disconnected.
Posted by Les Bamford on
Vladimir Frolov
  • Samsung Master
  • 2,075 Answers
That's the system/driver (in Note 3) problem with no full compatible BT device. Upgrade system.
Posted on Jan 25, 2018
  • Les Bamford
    Les Bamford Jan 25, 2018
    Already updated both phone and watch to latest software, still the same problem
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: linksys wireless connection keeps getting dropped
From you DSL modem or broadband router, what is the next device connected?
Posted on Nov 27, 2007
SOURCE: bluetooth conection
Make sure You have a Bluetooth device on your laptop[of course that is necessary].Now i recommend you to use WIDCOM bluetooth software.It is theeee best for bluetooth device handling.
Also make sure that the bluetooth device on your samsung blackjack is working.That can be done by asking your friend having a bluetooth enable phone to search for your mobile via bluetooth,be sure you turn on your bluetooth device on your mobile and make it visible to others.
Make sure after intalling the software (WIDCOM) the drivers are successfully intalled.Then pair it with your mobile.So simple isn't it
Please rate me my name is Karatela
Posted on Dec 05, 2007
Rishi Roshan Ali
  • 2427 Answers
you have to activate blue tooth connectivity on your phone
Posted on Dec 31, 2007
marked
Mark Gil
  • 6487 Answers
SOURCE: Laptop keeps dropping internet connection
This can be resolve by accessing the router setup page and changing the Wireless channel of your router if possible set it to the highest channel that is available on it , but if still the same thing the next thing to do here is to update the firmware of your router , you can get the firmware from the web site of your router's manufacturer....
Posted on Jul 17, 2009
Anonymous
SOURCE: Samsung F480 mobile bluetooth connection problems
two sybols on phone: Bluetooth and another with device name that it is trying to connect to. Drag the device name symbol onto the bluetooth symbol. will ask for password, then it will connect. there will be a dotted blue line now to the device it is connected to
Posted on Aug 05, 2009
HOW DO I CONNECT MY v8 SMART WATCH WITH MY SAMSUNG J4 PHONE
Most Smart watches and mobile phones are connected using Bluetooth. The watch will have a feature in "Settings" to turn on the Bluetooth. Also, On your phone, turn on the Bluetooth and it will search for the watch. They should 'pair' and give you access to your phone through your watch.
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Why have my Bluetooth stop pairing with my iPhone 4 it keep saying connection unsuccessful, now discoverable
Hi Timothy
Noise on the same frequency (channel) as your bluetooth connection can inter fear with the connection process.
Check the IOS version you are running. Update if needed via WiFi.
Try outside, away from WIFI & microwave ovens & hotspots & other smart phones & devices in your area.
Turn off your Bluetooth on the iPhone.
Reset the iPhone by quitting all Apps then Hold down Top & Round button together for 5 seconds or more.
Restart your phone with top button (3-4 seconds)
Erase the old bluetooth connection name and restart the discovery routine to establish a new connection.
Last Resort..... Do a full restore or the iPhones IOS
If all else fails.... drop in to your Apple Store
Good Luck
2answers
Can Bluetooth still work if the ihome is not plug into an outlet? Like can you take it places and can it be portable
Bluetooth is a smart replacement for connection cables. Thought for very low power information (music) exchange. It will connect devices over a range of maximal 10 yards. (about 10 meters) If you were using a bluetooth headphone to listen music on your iPod, as soon as you plug in a wired headphone, the bluetooth connection will be disconnected, because your device only can serve one master.
I hope I could shine any light on your blue tooth.
3answers
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
2answers
How do i make my pc discoverable to my samsung
enable wi-fi on your Samsung.You will need a wireless router if you do not already have one.
2answers
Charging problem
cant connect to hands free bluetooth when i search for a bluetooth its says it has not found a bluetooth handsfree
2answers
Bluetooth headphones no longer working
Hi found the sulution by going through the forum all I had to do was start the transmitterby holding power down for 15sec then the light changed to a red blinking one then the samsung connected straight away thanks
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
Muzahura Frank
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
