...PROBLEM: #3 stitch sews, but not as dense as the #1 stitch on the left. #4 and #5 finish fine.
Please tell us which Bernina 830 you have--old mechanical Record or new computerized?
Here's a recommendation from a Bernina owner (Ellen Rosenthal on Yahoo Group "BonosBerninas":
I agree about the buttonholer. The reverse stitching never looks as good as the left or forward side. I “hack” this by pivoting my fabric and only
going forward-avoiding the reverse stitch. Also helps to do the whole process twice and to use some tear away or wash away interfacing.
There is another Yahoo group called "BerninaThirtySomethings" that is a great resource.
SOURCE: Uneven buttonhole sides
Hi, I'm a Bernina tech and can tell you you need to have a technician recalibrate your buttonhole foot to the machine. There is a function in the service program to do this. Also the machine will need a speed calibration once the buttonhole foot is calibrated. This will definatly solve the problem.
SOURCE: EP 382 My user manual buttonhole instructions
Yes, you are right. To make out what is wrong place a plain cloth under the foot and try these 3 ABC positions as well as other positions and see what type of stitch you get in each position.
I don't claim this to be a solution to the problem. But it should help you solve it.
SOURCE: My Bernina 830 Sewing Machine is not sewing the
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
SOURCE: Buttonhole making instructions from the manual of
Some machines will start out by sewing a straight stitch all the way around the buttonhole area first and then will zigzag/satin stitch along the sides. Bar tacks will be the last stitches sewn - hope this helps!
SOURCE: I have a Bernina 830 sewing machine and I can't
Change the stitch width from zero to the width you want.
You can download a manual here - http://www.berninausa.com/news_detail-n486-r0-i2238-sUS.html
