SOURCE: Stuck on on intro screen
I just want to say thank you so much to Chrisdp for his solution my sony mp3 player was stuck on that screen as well, i reset it thanks to you mentioning the reset button It work! I noticed this happened after my machine went down when someone accidently hit the off switch on the power supply. Thanks Chris you ROCK! emunoz
SOURCE: rca dvd\vcr locked on hello
The hello issue is most likely a faulty DVD-RW. These go out on thse models more than usual. Reset is a combination of 2 buttons. Press and hold the play and disk tray open or the power and play ( i forgot the exact sequence but you get my drift, press 2 buttons for about 10 seconds). You can also update the firmware...or atleast could before from RCA.COM but they no longer support this midel. I do have the software update on CD but it won't do any good on Hello issue. If worst comes to worst, open the player up and replace the DVD-RW drive.
SOURCE: rca lyra rd1076a mp3 player
I have same one and I had same prob till I realized u gotta hold on button down for 5 secs to turn on. Just like when u turn on cell fone. I havent had prob since.
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
