Question about Electrolux Washing Machines
Front Load Washer is rinsing with hot water on a cold rinse cycle and is giving a Hose error message even though the hoses are correctly connected
I have the same model and same error and issue. Did you find your answer?! It has been an error code since it was installed by we haven’t had it looked at yet. I just realized today that no matter what setting I choose the clothes come out hot even if steam function is off
Posted on Feb 27, 2019
First try reversing the hoses to see if that remidies it.
Posted on Jan 25, 2018
Testimonial: "When doing a hot wash the water is hot, when doing a cold wash the wash is cold but the rince is hot..."
Ah! It does that so that the dishes dry better. Some heat the rinse/wash water with a element in the unit others use your hot water. The dry element will always come on creating steam that sometimes you can see coming out of the front vent.
Unless there is a air dry setting, but it still, will rinse with hot water.
Either way it is suppose to do that tis not like a cloths washer.
Hope this helps you understand your dishwasher.
Best to you.
the hose error may be due to the filter screen on the unit being restricted from minerals that are in the hot water and it catches.
If you remove the hose from the unit inspect the screen that should be in the part you connect the hose to. Check too the cold one.
Hope this helps.
? I am not asking about a dishwasher...
sorry about that!! I messed up the # input. I hate it when that happens!
comment # 2 hose error.. applies to all appliances using hose connections to hot and cold.
ck the hose screens. let me know.
Thanks! again sorry!
? I am not asking about a dish washer...
