Question about Rangemaster Kitchen Ranges
Rangemaster Prof 60 elec cooker purch Nov14 5yr warranty. Feb 17 top oven/grill stopped working, Rangemaster eng found back of switch melted and replaced unit. Oct 17 same fault and switch replaced
2 weeks later same fault Rangemaster now suggesting we employ electrician to test house electrics. Electrician I spoke to laughed and said get back to rangemaster. Any thoughts please
Posted by Jan Furze on
2 Related Answers
Anonymous
SOURCE: FAN OVEN NOT WORKING
power went off to the house now cant reset fan oven on hotpoint bs21
Posted on May 23, 2008
Ross Clifton
  • 136 Answers
SOURCE: Rangemaster Toledo 30 - The glass in the oven door
junk it and get a new one !!!!
Posted on Oct 25, 2009
New rangemaster prof.fx90 induction cooker but hob not working. - comes on if a ring is on if you touch the hob but no other lights come on + it won't heat up.
Induction stovetops wont heat until a metal pot is put on top of the element. They work through electromagnetism. These tops wont work with glass or aluminium pots. They have to be steel.
Nov 28, 2014 | Rangemaster Kitchen Ranges
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/Toledo90Gas.pdf
The manual for theToledo with both electric ovens can be found here:
http://www.rangemaster.co.uk/media/575792/toledo%2090%20dual%20fuel.pdf
The main product page for the toledo 90 can be found here:
http://www.rangemaster.co.uk/range-cooking/toledo-90.aspx
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
I just need to know how to switch the oven on, i have turned oven hobs to 180 and nothing is happening...what else do i need to press????
The clock must be set to the time of day before the righthand
oven will work. The manual can be found here:  http://www.rangemaster.co.uk/index_Rangemaster_Manuals.htm
Jan 11, 2010 | Rangemaster Range Cookers Kitchener 110...
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 03, 2009 | Ovens
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Sep 24, 2007 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
Aug 11, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Kitchen Ranges Logo
29 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Ekse
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
