Question about HP DeskJet 820cxi InkJet Printer
HP Deskjet 1000C
The printer will print about 1/3 of the page then thinks it is finished
Posted by mlamma7 on
Anonymous
    New Friend:
  • 75 Answers
Put some sewing machine oil on the silver slide bar.dont get any oil on other parts
Posted on May 10, 2010
How to print envelopes
Go to control panel on the computer Go to printers and faxes or printers Click on add a printer Select 'Add a local printer' and click on Next Use existing prot is already selected and next to that there is a drop down, from the drop down select virtual printer port or USB port (Usb0001...) Click on next, and on the next window; In manufaturer's box select Hp and in Printers box select Deskjet 990c Then keep clicking next and at last finish Try to print any test page and then try to print envelope Note: 1. Hp Deskjet 990c is the universal driver for all hp printers 2. This work around only works in the case of Windows Xp and Windows Vista not in Windows 7 3. In windows 7, instead of Deskjet 990c, we can use Deskjet 9800
Oct 27, 2010 | HP PSC 1610 All-In-One InkJet Printer
My HP psc 750 won't print. I just get blank pages.
Try This:
Click on start
Goto to control panel
Goto Printers and Faxes
Click on File
Click on Add a Printer
Select Local Printer Attached to this Computer
then select LPT : Port 1
Then select have disk ;
Right navigation bar select Hp
And in right select Deskjet 990c
Install the driver and finish the installation
even after that it doesn't prints
Then right on the printer icon (Deskjet 990c)
Click on properties
Click on the port tab
Select the Virtual USB port
Then try to print;
Otherwise reinstall the software from the downloaded version
Regards Soumajit
Sep 16, 2009 | HP PSC 750 All-In-One InkJet Printer
When I try to print a page it only prints the first sentence without the first few words and the second sentence without the last few words all the way down the page. Sometimes it prints the first two...
Install the temporary drivers
If the product is connected via network perform the below steps to add temporary drivers
1.On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2.Click Add a Printer.
3.Select Local printer attached to this computer. Please uncheck the option ‘Automatically detect plug and play printers’.
4.In the Add Printer dialog box, Select Standard TCP/IP port, and then click Next.
5.In the next window type IP Address of the printer. You can get the IP Address of your All-in-One by printing a Network configuration page on your All-in-One.
6.Under Manufacturer, scroll to and click HP.
7.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
8.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
9.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
10.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
11.Click Finish to complete the installation.
If the product is connected via USB Cable perform the below steps to add temporaty drivers
3.In the Add Printer dialog box, Select USB001 port, and then click Next.
4.Under Manufacturer, scroll to and click HP.
5.Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6.Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7.In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8.Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9.Click Finish to complete the installation.
After adding the temporary drivers, while printing from applicaiton you should need to do the following steps
1.In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2.In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Sep 11, 2009 | HP Office Equipment & Supplies
Not printing the whole of the page even all in black ink some parts are randomly missing
Install Temporary Drivers:
Step one: Install a temporary print driver
1. On the Windows task bar, click the Start icon, click Control Panel, and then double-click Printers and Faxes.
2. Click Add a Printer.
3. In the Add Printer dialog box, Select USB001 port, and then click Next.
4. Under Manufacturer, scroll to and click HP.
5. Under Printers, scroll to and click hp DeskJet 990c, and then click Next . The Type a printer name dialog box opens.
6. Make sure hp DeskJet 990c is listed in the Printer name box, click the Set as the default printer checkbox to clear it, and then click Next.
7. In the Printer Sharing dialog box, select the appropriate radio button to share the print driver or not, and then click Next.
8. Click Print a test page to make sure the print driver is working correctly, and then click Close. Click Troubleshoot printer problems to solve the issue if the test page does not print correctly.
9. Click Finish to complete the installation.
Step two: Designate the temporary print driver for two-sided print jobs
Follow these steps to use the temporary print driver each time you print a two-sided document.
1. In the program you are printing from, click File, and then click Print. The Print dialog box opens.
2. In the Name drop-down list, click hp DeskJet 990c, and then click OK to print.
Aug 18, 2009 | HP PSC 1350 All-In-One Thermal Printer
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
Jul 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Deskjet 3550 keeps printing in pink
HP Deskjet 3550 MODEL NUMBER:VCVRA-0202
Feb 05, 2009 | HP DeskJet 3550 InkJet Printer
Printer spits out blank page
This should solve this problem if you haven't already. It's real simple.
Nov 26, 2008 | HP Photosmart C7280 Laser Printer
Prints one page on many pages
I think the problem is now fixed: I reinstalled the HP printer drivers, and made sure to choose HP DeskJet 845c in the printer setup before I printed a document.
Aug 11, 2008 | HP DeskJet 845c Printer
It does'nt print...
If it is printing very faint or blank, it is the cartridge. If it is not printing at all, and you are getting blinking lights post them and we can help. Sorry kinda hard to understand your issue
Jan 09, 2008 | HP DeskJet 640c InkJet Printer
HP DeskJet 820cxi InkJet Printer Logo
Ekse
efs_perpends
efs_perpends
