Cars & Trucks Master
- Posted on Jan 23, 2018
Re: Where is the body control mod. on a 2000 excursion?
Generic Electronic Module (GEM)-Generic Electronic/Central Timer (GEM/CTM)
Removal
NOTE: The GEM must be reconfigured upon replacement. Refer to the scan tool help screen on the Ford Service Function (FSF) card to program tire size and axle ratio.
- CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.Disconnect the battery ground cable. For additional information, refer to Section 414-01.
- CAUTION: Use care when removing the instrument panel steering column cover (044F08) or damage to the cover locating tab may occur.Remove the instrument panel steering column cover.
- Unlock the retainers.
- Remove the instrument panel steering column cover.
- Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
- Loosen the bolts.
- Disconnect the bulkhead connectors.
- Position the instrument panel fuse junction panel aside.
- Remove the nuts.
- Remove the bolts.
- Remove the generic electronic module/central timer module (GEM/CTM).
- Disconnect the electrical connectors.
- Remove the screws.
- Remove the GEM/CTM.
- To install, reverse the removal procedure.
I believe ford calls it a gem module.
