SOURCE: Error 0210: Stuck Key 01
This is a system board POST/BIOS error code (nothing todo with Windows). The ERROR 210: is a standard POST (Power On Self Test) errormessage that indicates an error with the keyboard. The error condition is thata keyboard scan code was received from the keyboard when none was expected,after the keyboard was reset. If this occurs most of the time when you power on yoursystem, then it indicates that a key is sticking down or the key mechanical orelectrical parts are broken. Sometimes blowing out and cleaning out around thekeys will resolve this problem. Otherwise, you need to replace your keyboardwith a new (or at least a working) one.
SOURCE: ERROR 0210: Stuck key 7B,
if this Problem before windows you need to reset keyboard cable anf if the Problem still you need to replace the keyboard
else if the Problem after windows just repair the Windows
SOURCE: ERROR 0210: Stuck key 7B Press
There are issues with
the ThinkVantage Button at boot as it doesn't do what its suppose to. Just use the F1(BIOS Setup), F11(pre-boot/recovery
area) and F12(boot device
selection). Just
a reminder to practice press and release when pressing a button. We sometimes get impatient and do a key hold
down for a while rather than multiple
press and release. I
hope this would resolves your ERROR 0210: Stuck key
selection).
Just
press and release.
I hope this would resolves your ERROR 0210: Stuck key
