Question about Dual Audio Players & Recorders
Dual 505 - 2
Bought one "in the box" that had gone through the wringer in shipping. How do you properly "fit" the turntable in the wood base. Appears four springs and two screw type adjusters, but can't figure out the "magic" to get it in place and free floating.
Posted by gprice on
5 Related Answers
robotek
Graeme Ross
  • 1512 Answers
SOURCE: Azimuth Adjustment on Tascam 122MKIII Cassette Deck
the screws are sometimes locked with Loctite or similer and the screw slot may be blocked up also. wetting the screw head with acetone will help to allow for the blocked screw head to soften. BE CAREFUL WITH ACETONE. it will damage plastic!!
Posted on Dec 09, 2007
Anonymous
SOURCE: Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Posted on Sep 23, 2008
Anonymous
  • 3 Answers
SOURCE: Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Posted on Jan 04, 2009
Anonymous
  • 4 Answers
SOURCE: looking to put together bassett
http://www.babyage.com/icons/localhost/products/multimedia/14782_M5501b.pdf
THIS IS A GOOD PICTURE IF YOU HAVE THE SAME KIND OF CRIB i DO.. THESE INSTRUCTIONS WILL WORK. i JUST PUT MINE TOGETHER USING THEM
Posted on Feb 24, 2009
FlyingLabRat
Dustin Reuber
  • 468 Answers
SOURCE: Float spring on tecumseh Carb.
Ok, that pin is the needle valve. It should move freely, and the spring should attach it to the float. When the carburetor bowl is full, the float pushes that pin up to shut off the gas flowing into it. Otherwise, it would continue to dump fuel into it until it overflows, and you would have gas all over. The engine draws gas through the jet in the bottom of sump that you see sticking into the bottom of the bowl(this likes to get plugged up and keep your engine from running) The spring just kind of sits in there so that if the float moves, it will pull down the pin as it moves.
Posted on Feb 01, 2010
Where can I get spares for a Dual 505 Turntable? Ineed the perspex cover.
I don't think you will get a replacement for that model itself.
However you can have one made for it. Just search the web for "Turntable Perspex Cover replacements".
Jan 29, 2015 | Audio Players & Recorders
Turntable manual
See http://www.audiokarma.org/forums/showthread.php?t=565478
Mar 30, 2014 | Audio Players & Recorders
What type of amp needed for Dual 505 turntable?
make sure a new amp has a phono input (a sensitive high impedance input)
Apr 16, 2012 | Audio Players & Recorders
My Dual CS 1264 Does not work. The arm swings out over the record, drops slightly and then returns to its resting position on its base
It seems that the special grease is old. There is a wheel moving the toneam. Remove any old grease from it and try again. If you need further instructions or a way to get new grease please refer to www. dual-board.de This is the worlds largest knowledge base for vintage Dual turntables. It is in german, but feel free to post in english, most people here in germany speak english, too.
Mar 24, 2012 | Dual Audio Players & Recorders
Plate leans to one side, dragging base as it turns
Ship it straight back, but get an RMA first if you bought it on-line.
If its from a shop same deal take it back and ask for another (do not accept it being repaired)
I understand that when we get a new toy we want to play. But I would hate to play with a new toy that I knew was repaired from new. That would take a lot of the pleasure out of it.
Aug 18, 2009 | RCA ION-ITTUSB05 Turntable
Conect my pick up with my stereo SH EH 760
Whats a pick up dual 505-2 belt drive? some kind of deck i.e turntable.if it is then plug it in the phono socket & then earth it to the ground screw to stop it humming. Failing than that u will need a mixer a small **** one will do. the same aplies plug it in the phono socket & then earth it to the ground screw come out of the MASTER or the BOOTH.out put in to the AUX or VCR in put on the HI FI....... & then If u wanted you could Then come back throu the VCR out puts into a CD or TAPE Recorder.
Jun 04, 2009 | Technics SC-DV290 System
Low volume through amp
you will probably need to buy a phono pre amp , i have a Dual 505 turntable that worked fine on my ROTEL amp but when i changed amps and went to NAD i had to buy a phono pre amp or else listen to really low sound . hope this helps
May 23, 2009 | Technics SL-1200MK2 Turntable
What is tracking force and arm weight for Dual 505-2 deck?
http://ortofon.de/ should give you the weight. It should also give you the range of tracking force. To get the right weight you can use a stylus balance. The electronic ones are expensive but good. The mechanical ones are not great but better than nothing. I set my turntable up with an Ortofon-branded mechanical balance for weight, and a test record for tracking force.
Apr 09, 2009 | Audio Players & Recorders
Dual 1009. No audio from the stylus & humming.
Trace all the connections to the cartridge. One way to do this is touching all audio input lines with a metal or screwdriver (holding the metal part and not the handle) while connected to the receiver with the volume turned up a abit to hear the 60hz humming sound. A louder humming sound will indicate a good connection path. Check also for good shielding of the audio wires to the cartridge. Generally, it's a wire problem troubleshooting.
WARNING!!! don't do this unless you know what you are doing. Don't ever touch the AC voltage wires OR someone will hum your mishap :-)
Jan 13, 2009 | Technics SL-1200 Turntable
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Top Dual Audio Players & Recorders Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Are you a Dual Audio Player and Recorder Expert? Answer questions, earn points and help others
