Question about Minn Kota Maxxum 70 Universal Motor/Sonar Combo
Minn Kota tolling motor
Trolling motor went forward when was in reverse mode. I then reversed wires
because I changed out the plug and thought I had wires switched. The who built boat didn't have a 50 amp fuse in it. Please advise.
Posted by 4513Wayne on
  • Anonymous Oct 22, 2008
    New in box.  Three forward gears, five reverse speeds.
    Assembled backwards?
    This was the 30 lb Minn Kota Endura.
vonny grace
Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
Posted on Jan 09, 2008
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota trolling motor has forward but no reverse
    Don't know what Minn Kota you are talking abut but my 55 pound Thrust one does NOT have a Reverse.... When I want reverse I swing the Prop all the way around so it is pulling the boat backwards..... I just checked it to refresh my memory......
    May 08, 2014 | Minn Kota Boating
    Reverse is forward and vice versa
    To get a dc motor to spin in reverse you have to change the polarity of the battery. This is normally done in the switch by which set of poles is connected . Have you connected the battery up correctly in the first instance.
    Jul 13, 2013 | Minn Kota Endura 40 Transom Mount Trolling...
    MY MINN KOTA 30LB THRUST MOTOR HAS DEVELOPED A NOISE IN THE LOWER UNIT LIKE A LOOSE BEARING.IT SEEMS TO BE WORSE IN REVERSE
    Hi!
    Here is a schematic for your motor:
    Endura 30
    It sounds like the motor has leaked water into it and wil need to be cleaned up, have the brushes, seal kit and bearings replaced.
    Best of luck!
    Mike
    Jul 09, 2009 | Minn Kota Endura 30 Freshwater Transom...
    I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
    Contact the people at this Email address. Minn Kota <[email protected]> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    GPS Logo
    492 people viewed this question
    Top Minn Kota GPS Experts
    Marvin
    Marvin
    Andrew Taylor
    Andrew Taylor
    Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
