Question about Motorola Mobility RAZR V3
Keypad my up down left right and 9 button just work sumtimes & i got another keypad just dont know how 2 get it out
Posted by texas_pete on
Anonymous
  • 31 Answers
The problem is not with the keypad. if u squeeze the bottom right hand corner of the fone where it slopes up all the problem keys work fine, so the problem is on the main board
Posted on Nov 26, 2007
Zaid Anarwala
  • 457 Answers
Open it ang change if u dont want to change open keypad circuit and clean it with eraser.I AM SERIOUS.
Posted on Nov 24, 2007
Ttack and spedometer wont work sumtime and when it doesn't transmission dont shift right
Take it to a tranmission shop to be road test , They don,t charge to do that,
Nov 29, 2012 | Cars & Trucks
How can I get the F/A -18 Precision Strike Fighter keyboard reference guide
Aileron Left Keypad 4
Aileron Right Keypad 6
Elevator Down Keypad 8
Elevator Up Keypad 5
Rudder Left <
Rudder Center /
Rudder Right >
Increase Thrust =
Decrease Thrust -
Afterburner Backspace
Brake Space
Gear G
Flap F
Hook H
Dump Fuel Shift D
Refuel Shift F
Service (refuel/arm) Shift S
Eject Shift E
Damage Display D
Engine Display E
HUD Options
HUD Altimeter Toggle Ctrl A
HUD Brightness Ctrl B
HUD Clutter Reject Ctrl C
NAVIGATION
Autopilot Toggle A
Autopilot Mode Shift A
Waypoint Cycle W
TACAN Cycle T
ILS Toggle L
Moving Map/Scale M
Nav./HSI Scale N
RADAR
AA/AG Toggle R
Sub-mode Cycle Q
Standby B
IFF Interrogate I
Range Decrease Tab
Range Increase Shift Tab
ACM Cycle Shift R
AACQ Cycle Shift Q
Silent Mode Ctrl R
Radar Target
Designate/Cycle \
Undesignate/TDC Stow Shift \
TDC Up Shift Arrow Up
TDC Down Shift Arrow Down
TDC Left Shift Arrow Left
TDC Right Shift Arrow Right
Radar Scan Volume
Decrease Azimuth Z
Decrease Elevation X
Increase Azimuth Shift Z
Increase Elevation Shift X
WEAPONS
Stores Display S
Cycle AA [
Cycle AG ]
CCIP/Auto Toggle Shift ]
Jettison Station J
Release Flare '
Release Chaff ;
ECM Toggle C
Designate/Release Enter
Electro-Optical
E-O Weapon Cycle O
E-O Target Cycle Ctrl \
HARM
HARM Select U
HARM Target Cycle Ctrl \
SIMULATION
Pause Flight P
Exit Flight Shift Esc
Fast-time Toggle Ctrl F
Warp-time Toggle Ctrl W
Earlier TOD Ctrl E
Later TOD Ctrl L
Night/Day (+6 hr) Ctrl N
Joystick Program Ctrl J
Hide Instruments Ctrl I
RADIO MESSAGING
Ground Control Shift G
Control Tower Shift T
Flight Ops Shift O
Approach Control Shift C
Landing Signal Officer Shift L
WINGMAN COMMANDS
F1: Wingman flies to your 4 o'clock position.
F2: Engage/protect my air target.
F3: Resume your mission objectives.
F4: RTB or Return To Base. I use this only when my wingman is low on fuel (he will call "Bingo" when he has just enough fuel left to return to base).
Tactical pre-merge setup:
F5: "Bracket left" or flies to your left side (9 o'clock).
F6: "Bracket right" or flies to your right side (3 o'clock).
F7: "Split High" or flies at your right at a higher level.
F8: "Split Low" or flies at your left at a lower level.
Admin commands:
F9: Echelon. Parade position at your 4 o'clock.
F10: Trail. At your six o'clock.
F11: Combat spread.
F12: Lead. In front of you.
VIEWS
Cockpit Views
Forward 1
Look Down 2
External View 3
Selected Target 4
My Aircraft 5
Padlock Target 6
Padlock Nearest 7
Padlock Wingman 8
In-flight Weapon Toggle 9
Radar Target Toggle 0
VIEW MODIFIERS
Look Left Arrow Left
Look Up Arrow Up
Look Right Arrow Right
Look Back Arrow Down
Optical Zoom In Home
Optical Zoom Out End
Move Camera In Page Up
Move Camera Out Page Down
Multiplayer Chat Shift '
AA: Air-to-Air
AMRAAM: Advanced Medium-Range Air-to-Air Missile
AS: Air-to-Surface
HARM: High-speed Anti-Radiation Missile
HD: High-Drag
LD: Low-Drag
LGB: Laser Guided Bomb
STORES DESCRIPTION
AIM-9M Sidewinder (190 lbs.) Short-range infrared-guided (heat-seeking) AA missile
AIM-9Mx2 Sidewinder (380 lbs.) Short-range infrared-guided (heat-seeking) AA missile
AIM-120 AMRAAM (350 lbs.) Advanced medium-range radar-guided AA missile
AGM-65B Maverick (645 lbs.) Electro-optically guided AS missile
AGM-88 HARM (790 lbs.) High-speed anti-radiation radar-homing AS missile
AGM-62 Walleye (1250 lbs.) Electro-optically guided gliding AS missile
MK-82 LGB (600 lbs.) Laser-guided general-purpose light bomb
MK-83 LGB (1100 lbs.) Laser-guided general-purpose medium bomb
MK-84 LGB (2100 lbs.) Laser-guided general-purpose heavy bomb
MK-82 LDx2 Slick (1040 lbs.) Free-fall general-purpose low-drag light bomb
MK-83 LDx2 Slick (2130 lbs.) Free-fall general-purpose low-drag medium bomb
MK-84 LD Slick (1980 lbs.) Free-fall general-purpose low-drag heavy bomb
MK-82 HDx2 Snakeye (1160 lbs.) Free-fall general-purpose high-drag light bomb
CBU-59B Cluster (490 lbs.) Free-fall anti-personnel and munitions bomb
B-57 Nuke (650 lbs.) Free-fall tactical thermonuclear bomb
BLU-107B Durandal (483 lbs.) Rocket-powered anti-runway bomb
EXT FUEL (2500 lbs.) Disposable fuel tank
FLIR (350 lbs.) Forward looking infrared pod / Electro-optical targeting device
RECOMMENDED LOADOUTS
Mission Type
Station=>Store
Patrol
1/9=>AIM-9M, 2/8=>(Empty), 3/7=>(Empty), 4/6=>(Empty), 5=>(Empty)
Medium Range CAP (Combat Air Patrol)
1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>(Empty), 4/6=>AIM-120, 5=>EXT FUEL
Short Range CAP (Combat Air Patrol)
1/9=>AIM-9M, 2/8=>AIM-9Mx2, 3/7=>(Empty), 4/6=>AIM-120, 5=>(Empty)
Escort
1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>EXT FUEL
Intercept
1/9=>AIM-9M, 2/8=>AIM-120, 3/7=>EXT FUEL, 4/6=>AIM-120, 5=>(Empty)
Ferry
1/9=>AIM-9M, 2/8=>(Empty), 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
CAS (Close Air Support)
1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-88, 4/6=>(Empty), 5=>CBU-59B
SEAD (Suppress Enemy Air Defenses)
1/9=>AIM-9M, 2/8=>AGM-88, 3/7=>AGM-88, 4/6=>AIM-120, 5=>EXT FUEL
Light Free-Fall Strike
1/9=>AIM-9M, 2/8=>MK-82 LDx2, 3/7=>(Empty), 4/6=>(Empty), 5=>EXT FUEL
Heavy Laser-Guided (Precision) Strike
1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>MK-84 LGB, 4/6=>(Empty), 5=>EXT FUEL
Heavy Free-Fall Strike
1/9=>AIM-9M, 2/8=>MK-83 LDx2, 3/7=>MK-83 LDx2, 4/6=>(Empty), 5=>EXT FUEL
Deep Interdiction Strike
1/9=>AIM-9M, 2/8=>MK-84 LGB, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
Nuclear Strike
1/9=>AIM-9M, 2/8=>B-57, 3/7=>EXT FUEL, 4/6=>(Empty), 5=>EXT FUEL
Anti-Runway
1/9=>AIM-9M, 2/8=>MK-82 HDx2, 3/7=>BLU-107B, 4/6=>(Empty), 5=>MK-82 HDx2
Anti-Tank
1/9=>AIM-9M, 2/8=>AGM-65B, 3/7=>AGM-65B, 4/6=>(Empty), 5=>(Empty)
Jan 26, 2012 | Xicat Interactive F/A -18 Precision Strike...
Keypad's 7&* not working
This picture repair guide may help to diagnose and repair on nokia X2 mobile phone handset.
Just follow the instructions stated on the picture itself.
Keypads key configuration by Rows and Columns
Row 0 = soft left, left, soft right, right
Row 1 = send, up, , down, camera
Row 2 = 1, 2, 3, select,
Row 3 = 4, 5, 6, volume up
Row 4 = 7, 8, 9, voume down
Row 5 = * , 0, #
Row 6 = music play, music forward, music rewind
Column 0 = soft left, send, 1, 4, 7, *, music play
Column 1 = left, up, 2, 5, 8, 0, music forward
Column 2 = soft right, 3, 6, 9, #, music rewind, camera
Column 3 = right, down, select, volume up, volume down,
Jan 05, 2012 | Nokia 5700 Cellular Phone
My Up, Right, 9 and Left key dont work .. how do I fix it?
The metal parts of your keypad may have corroded. Have your keypad replaced by an authorized service center. or you may try this temporary solution.. just keep on pressing and pressing the keys until it works.It may take a while to correct the problem.
Mar 09, 2011 | Motorola Mobility ROKR E8 Cellular Phone
The keypad 3, 6 and 9 of my sonyericcson k750i are not functioning....
If you feel confident and competent enough, try taking your phone apart and giving the internals a good clean, take the white keypad PCB out and clean both it's contacts and the contacts on the phone's mainboard, and clear out any dust. Put the phone back together and see if that's solved the problem. It could also simply be that the keypad connector has worked loose
Key Pressed : Key presses phone appears to see
3 : 3 then left soft key
6 : 6 then right soft key
9 : 9 then back
c : c then #
left soft key : 3 then left soft key
right soft key : 6 then right soft key
(All the other keys worked correctly)
As I didn’t know what was causing this I attempted to move all data stored on the phone to the memorystick so I could master reset and possibly reflash, although after this I returned to the homescreen to find all keys had started functioning correctly again,
9 : 9 then back
c : c then #
Jun 25, 2009 | Sony Ericsson K750i Cellular Phone
How do i unlock my e63 nokia?
its easy
only 1- press on up right botton
2- press on down right botton
that's all
Mar 09, 2009 | Nokia E63 Cell Phone
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 08, 2009 | Sony Z310a Cellular Phone
Mortalkombat cheatcodes
There arnt any cheats but there are hints
Mortal Kombat: Shaolin Monks Hints playstation2.jpg Kung Lao Fatalities list Fatality 1: LEFT, UP, RIGHT, RIGHT, QUICK
Fatality 2: RIGHT, RIGHT, RIGHT, RIGHT, QUICK
Fatality 3: UP, UP, UP, RIGHT, QUICK
Fatality 4: UP, UP, UP, DOWN, QUICK
Fatality 5: LEFT, RIGHT, LEFT, DOWN, QUICK
Fatality 6: LEFT, RIGHT, LEFT, LEFT, QUICK
Fatality 7: UP, UP, LEFT, UP, QUICK
Fatality 8: UP, DOWN, UP, RIGHT, QUICK
Fatality 9: RIGHT, RIGHT, UP, UP, QUICK
Mutality 1: UP, RIGHT, DOWN, LEFT, LAUNCH
Mutality 2: LEFT, RIGHT, RIGHT, LEFT, LAUNCH
Brutality 1: LEFT, LEFT, UP, UP, POWER
Liu-Kang Fatalities list Fatality 1: DOWN, LEFT, RIGHT, UP, QUICK
Fatality 2: DOWN, LEFT, UP, RIGHT, QUICK
Fatality 3: LEFT, UP, UP, RIGHT, QUICK
Fatality 4: LEFT, RIGHT, DOWN, DOWN, QUICK
Fatality 5: UP, RIGHT, DOWN, LEFT, QUICK
Fatality 6: DOWN, RIGHT, LEFT, LEFT, QUICK
Fatality 7: LEFT, LEFT, LEFT, UP, QUICK
Fatality 8: RIGHT, UP, RIGHT, UP, QUICK
Fatality 9: RIGHT, LEFT, DOWN, DOWN, QUICK
Mutality 1: UP, DOWN, UP, DOWN, LAUNCH
Mutality 2: LEFT, RIGHT, UP, UP, LAUNCH
Brutality 1: RIGHT, UP, DOWN, DOWN, POWER
Baraka Fatalities (VS Mode) Fatality 1: DOWN, LEFT, RIGHT, RIGHT, QUICK
Fatality 2: LEFT, LEFT, LEFT, LEFT, QUICK
Johnny Cage Fatalities (VS Mode) Fatality 1: DOWN, DOWN, RIGHT, RIGHT, QUICK
Kitana Fatalities (VS Mode) Fatality 1: LEFT, LEFT, RIGHT, RIGHT, QUICK
Reptile Fatalities (VS Mode) Fatality 1: LEFT, RIGHT, LEFT, DOWN, QUICK
Fatality 2: LEFT, LEFT, LEFT, DOWN, QUICK
Dec 18, 2008 | Sony PlayStation 2 Slimline Console
Keypad problem
hi my n73 keypad is nt working' all keys nt work
Jun 02, 2008 | Nokia N73 Cellular Phone
Cheat
Hi as i have the game i have just tried the cheats i have found on the internet this is when you use them when the games loaded and it scans the memory card and loads of the memory card.
You know when the games on and you can select the menus like career mode and my cars dont select not then enter the cheats here.
The first couple of goes it didnt work but i found that if you do it fast it works fine ok.
Heres the list of cheats ive got off the net that i have just tried and do work make sure you do it fast enough and press the buttons hard enough else it dont work ok heres the list i got. The only one i couldnt get to work was castrol crash ok but the rest worked fine.
1. up up down down down down up square (unlock cardboard box and driver vinyl)
2. right up down up down left right square (unlock nfs:c vinyl)
3. down up up right left left right square (unlimited crew change)
4. down right right left right up down square (unlimited speed break)
5. down up left down right up square triangle (castrol crash)
6. left up left down left down right square (inf nitrous)
Remember make sure you press the control pad hard enough ok let me know if your having any problems ok also if your cheats are different let me know then i can try them for you ok
Mar 20, 2008 | Sony PlayStation 2 (PS2) Console
Motorola Mobility RAZR V3 Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Vernon Taylor
Jeff
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
