After I did the diagnostics test and it came up 88,I pressed the button again and it said 4d what does it mean
SOURCE: whirlpool cabrio error code f51 what does it mean?
Lefty, the code means a rotor position sensor error. The first thing you want to do is see if the basket turns freely by hand. I had one the other day where a dish towell was caught between the basket and tub giving the error. You will have to open the top by using a putty knife and pushing in on the clips on each side. They are strong clips so you have to use some force. The whole top will lift up. Next you will have to remove the tub ring. It just snaps off. If you don't find anything between them, then I would suspect the rotor sensor itself. At the factory they sprayed a protective coating on them and sometimes this causes the problem. You would have to tip the washer back. The motor cover comes off witha allen head, just pulls down. Now there is 4 screws that hold the motor in place. Once you drop them, the plastic cover protector will come down along with the motor so observe carefully where it mounts back up. The motor connector will be the 3 pronged harness on the right side of the motor. The rotor position sensor will be on the left. Snap the positon sensor in and out about 8 or 9 times to get the coating off. If this doesn't work, and you keep getting the error, you will have to order the position sensor. I have had to order the harness as well in some cases. Catriver.
SOURCE: error code AF Whirlpool cabrio dryer
I found the answer to the code AF also and it means the air flow is blocked. I checked my dryer vent on the outside and it was clear. However when I removed the dryer duct it was clogged just inside the machine. I had washed and dried a blanket that shed alot!
SOURCE: F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
SOURCE: I have a whirlpool Cabrio, what does LF error code
The LF error is a water supply fault. Both water supplies must be connected and fully opened. The inlet hoses and valves both have strainers that may need cleaning as this could obstruct the water flow and also check that you don't have any water leaks. The unit requires a minimum water pressure to operate so anything that could prevent the unit getting this pressure will cause this fault. Hope this helps you out!
