SOURCE: Toshiba Satellite A60, reset to defalut...how?
With that machine, the recovery disks came with it when new. You can, however, install any retail version of the operating system, and go to www.toshiba.com to download/install the required device drivers.
SOURCE: how do i restore a toshiba L350 laptop to factory
Hello, Bob.
Use the Recovery CDs that came with the system. If you no longer have them, order them through Toshiba. Here's their website:
http://www.toshiba.com/tai/
Hope this helps.
SOURCE: Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
SOURCE: How do I fix error:
Hold in the number 0 while the pc boots it should take you to the restore factory settings option, once follow any instructions and it should recover the problem.
If not you should take it back to the shop you bought it as it is a windows fault, and as most Toshiba pcs do not come with any recovery disks now, they can send it back to the manufgacturer to be repaired. The fault is a windows activation error so as long as you have a warrenty or recite of purchase they may even replace it for you.hope this helps.
SOURCE: I recieved error 10-FA12-045D after
Error codes starting with 10 on Toshiba laptops point to a hard drive failure. The drive is most likely dead and cannot be revived. You will need to replace the drive and then reinstall the operating system.
