Question about Maytag Washing Machines
Maytag bravos mct washer keeps filling with water on drain and spin cycly
After running a " normal" cycle clothes are still soaked and when i run a drain and spin cycle. Instead of spinning out it continues to add water and thus still leaving clothes soaking wet
Posted by Jim Lockburner on
  • Whirlpool
    Whirlpool Mar 09, 2018
    Jim, we’re sorry to hear of the concerns you're having with your Maytag® Washer. We'd like to follow up with you regarding your concerns. Please email us at [email protected] with your name, phone number, address, the website you were contacted on (Fixya), the model/serial number and date of purchase so we may do so. Please include a brief description of your concerns in your email. Thank you Maytag® Social Care
  • Charles Thurston
    Charles Thurston Mar 30, 2019
    I also am having this same problem, may I ask what the fix was?
vince
  • Maytag Master
  • 1,234 Answers
First thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
Posted on Jan 21, 2018
5 Related Answers
Ronnie Houston
  • 2920 Answers
SOURCE: Washer won't drain during the spin cycle
you would need to get to the pump,,,its probably a sock of some piece of clothing stuck in the pump. its under the washer.drano wont help with this sorry
Posted on Feb 01, 2009
quady
  • 142 Answers
SOURCE: Washer will not spin at high speed
check for any blockages around pump and air trap area.
Posted on Sep 14, 2009
Anonymous
  • 512 Answers
SOURCE: Washer drains then spins then fills again and drains but no spin
Try this, unplug washer for two minutes, plug back in, open and close lid seven times slowly, this will reset the computer and the electronic motor. Also on water level switch, make sure hose from switch to tub is not plugged, blow it out, gets clogged with soap.
Posted on Sep 23, 2009
PRIMOAPPLIAN
  • 401 Answers
SOURCE: Washer works on every setting but does not spin on spin cycle
IF ITS A TOP LOADER ITS POSSABLE YOU HAVE A BAD CLUTCH IT A FRONT LOADER YOU MAYBE USING TOO MUCH SOAP
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Jan 12, 2010
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: During the spin cycle water pours continuously like fill cycle
This problem is commonly attributed to either a water inlet valve leaking by, or a pressure switch malfunction. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I've included parts sources (if required) and how to repair each problem. If you have any questions, please post back and let me know. I hope this information is helpful to you.
Posted on Mar 19, 2010
Maytag Bravos top load washing machine "clean washer" feature doesnt work.
This feature does not have to be used and should not affect the normal operation.SUGGESTION..Use BORAX according to instructions on box and run normal cycle with clothing.This will help disinfect and clean your unit.
Happy Holidays
Nov 21, 2017 | Maytag Washing Machines
My bravo washer is not starting a cycle when I press start button. Also water is still in tub from last load that did not drain.
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Feb 20, 2016 | Maytag Dryers
Maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
Nov 20, 2012 | Washing Machines
OL error code
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Jun 03, 2012 | Maytag Bravos MTW6600T Top Load Washer
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
Spin cycle
it sounds like there is either an obstruction in the pump, or the load is getting off balance during the spin cycle. two things to try, fill the washer with no cloths in it, when it starts to agitate, stop the cycle and put it in drain/spin cycle. the water should be out in under a minute. its hard to see because the door locks, but you can hear a difference in the pump when its out, or after 60 seconds, press cancel and open the lid to check. if the waters out in that time, the pumps ok. then run it through the spin diagnostic with a load of cloths. make sure the cloths are wet, and a normal load you wash. this will check to see if the load is getting off balance, and shutting down during the spin cycle. let me know if you still have the problem. good luck, shane
Aug 23, 2009 | Maytag Neptune Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
2,502 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
