Question about Kenmore Vacuums
SOURCE: Kenmore canister vac 25614
Have you checked and made sure that the hose is COMPLETELY clear and the bag is not full?
Posted on Feb 13, 2009
SOURCE: the wand has no suction
There's a clog somewhere then - probably at the end of the hose which means you should take off the hose at the bottom by the cord clip and have a look. Also check all inspection air ways to ensure there are no clogs. Usually if there's no suction through the handle a tell tale sign is that something has either got stuck or there's a tear in the hose. Hope that helps.
Posted on Feb 27, 2009
SOURCE: hi my dyson dc18 has great suction from wand but
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Posted on May 23, 2010
SOURCE: My Dyson absolute vaccume has
Check the ducting that goes from the floor pick-up into the machine, fluff etc often clogs the elbow. Check the pipe that plugs into the floor pick-up as well, it could be clogged further up.
Posted on Jan 28, 2011
check this video out
Posted on Nov 18, 2012
