Cars & Trucks Logo
R
Robin Hamade Gammon Posted on Jan 21, 2018
The light went out in my Cabrio Dyer how can I fix it?
How to fix the airbag warning light on the dash of vw cabrio 1999?
Just removve the light if you do not need it. Or bring to a garage and have them hook it to a computer and turn it off. Or see if by disconnecting the battery for 5 to ten minutes anbd then reconnecting.
How do i fix a faulty ignition swicth on a '97 cabrio?
The wiring should not be crossed unless it was in a bad accident that pinched wires or a repair was done to it by someone who did not know what they were doing.
You seem to have several issues, if you are mechanically inclined, I would recommend that you begin by replacing both, ignition switch and the turn signal switch, which also activates your high / low beam. Then proceed diagnosing the park brake problem and finally your ABS issue.
1997 vw cabrio driver door does not turn on dome light. Passenger side works fine. How do I troubleshoot and fix?
Check the switch in the door-jam. Little black plunger that pushes against door when closed, you'll probably find your driver doors switch is stuck in/or broken.
2000 VW Cabrio Car just stops running while driving and Wont start back up . I have Changed the Coil what else could it be
Mas air flow sensor went on my cabrio, pretty easy to fix, when it went my car would lose power sputter then die out. also could be spark plugs fuel pump, fuel pessure regulator,
2answers
Have an audi a4 1.8T Cabrio. Battery went dead,
You will need to put the car on a scanner to reset.
My Cigarette Lighter in my 97' VW Cabrio went out.. I have not found a Blown Fuse. What else could i look for to repair it?
Check to see if there is power in the socket with a test light. If there is no power, you have a blown fuse. If there is power, it's probably just dirty, or poorly grounded.
Unable to start my 2001 cabrio vw. I have a fairly new battery. Lights work. When I turn the key, there's nothing not a crank, nothing.
I would look to see if the anti-theft light is on next to the door lock. A 95 cabrio did this when I was test driving it. All we did was get out of the vehicle and manual lock and unlock the car, then it went away. This could definitely be more complicated than this, but always worth a try.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
