Reddy heater with a spark plug but no spark. Uses kerosene.
The electrodes might need cleaned. I am attaching a link, please check out the FAQ section, then scroll down and click on FAQ for spark plug heaters. I hope this helps. Reddy Heater Parts Sales Online Mr Reddy Heater Parts Master Heater Parts...
Posted on Jan 21, 2018
SOURCE: Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Posted on Dec 06, 2007
SOURCE: Reddy Heater Kerosene 50,000 BTU produces TOO
There are2- adjustment screws on the back 1--air---#2-fuel. adjust it while running for the perfect combination for the fuel/ air ratio.!
Posted on Dec 22, 2009
SOURCE: I have a Reddy Pro 115 BTU kerosene heater the fan
When you say that the fan starts then stops I assume you also mean that the burner starts and stops. If this is correct and the unit is more than a couple of years old you probably need to change the filter in the back and set the pump pressure. Both the filters and the gauges to set the pressure can be found at www.reddyheat.com along with a good explanation as to why you need the gauges. The pressure is set by bleed air pressure and must be exactly 3.5 psig. The gauge is the only accurate way to do it. The filters clog and change the pressure. When the difference is enough the unit will not run. Now with that said there are several other things which you should check. Check the fuel tank for water. Remove any you find. Remove the cover on the right side as you look at the unit from the front and remove the circuit board. Check for cracked connections. If you find any resolder them and reattach the board. That should take care of the unit and get you back to making heat. Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Posted on Feb 14, 2010
SOURCE: i have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
heatman101
Jan 27, 2014 | Reddy Heater-30,000 BTU Propane Forced-Air...
Jan 14, 2012 | Reddy Heater-170,000 BTU Kerosene Deluxe
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
Torpedo
heatman101
Feb 13, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Jan 23, 2011 | Reddy Heater-30-55,000 BTU Variable
heatman101
==-0-
Jan 22, 2011 | Reddy Heater-70,000 BTU Kerosene w/T'stat
heatman101
Dec 19, 2010 | All-Pro Forced Air Kerosene Space Heater...
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Nov 20, 2009 | Reddy Kerosene Heater with Thermostat:...
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Nov 29, 2007 | All-Pro Kerosene Garage Shop Heaters - All...
669 people viewed this question
