Question about Casio Office Equipment & Supplies
SOURCE: paper jam MP 210
did you close tightly the cover of your printer? try to check it then print a sample if it is desame
Posted on Apr 01, 2008
SOURCE: small tear on plastic lining covering the inside of the door
That clear cover (sometimes called the inner door screen) is very important.
It protects the metal mesh / screen from debris and corrosion. The metal screen allows you to see "what's cooking" (*grin*) but prevents microwaves from leaking out of the door due to the precise size of the openings in the mesh.
If the mesh rusts or gets grease or food on it, it can arc, and this can damage the screen, then microwaves can leak, causing a burn or fire hazard. (No "radiation" threat, though)
If no arcing or other damage has occurred yet, you can clean the area squeaky with alcohol, then dry it completely and use the smallest possible amount of clear Scotch tape or packing tape to cover the tear and make sure it's flat.
If this fix doesn't work, or it's too big an area, you will have to replace the sheet, which can be ordered.
You'd have to heat it up with a hair dryer, peel it off slowly, then clean the area with something like acetone, then peel and stick the new one.
If you need to or prefer to order it, I would need your brand and model number to help you further.
Posted on Oct 07, 2008
SOURCE: The small piece of plastic (with BOSE on it)that
You can have Bose replace the headset for you (new w/ 1-year warranty), but if it's past it's current 1-year it will cost you $60.Unfortunately Bose doesn't supply parts for that headset, but you could try using plastic adhesive as a low-tech fix. First Google search result for plastic adhesive:http://solutions.3m.com/wps/portal/3M/en_US/Windows/Doors/Product-Information/Products/Adhesives/Plastic-Adhesive/ .
Posted on Jun 12, 2009
Oct 29, 2010 | Canon ImageClass D861 Printer
Nov 03, 2009 | Dell Photo 964 All-In-One InkJet Printer
Aug 31, 2009 | HP Office Equipment & Supplies
Jun 08, 2009 | Canon Pixma MP800 All-In-One InkJet...
Apr 14, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
Jan 19, 2009 | HP LaserJet 2820 Printer
Jan 17, 2009 | HP Officejet 6310 All-In-One InkJet...
Dec 20, 2008 | Canon PIXMA iP1600 Printer
Sep 30, 2008 | HP PSC 1315 All-In-One InkJet Printer
Sep 22, 2008 | Canon Pixma iP4500 InkJet Printer
