Question about Springfield Measuring Tools & Sensors
I have an older model springfield precise outdoor temp not registering on indoor unit. Batteries have been changed, reset button pushed. Model #EMR899. Cable free
Posted by kerry crandall on
Ken Richardson
Steve, thanks for that info on the reset button , I go through this every time I change batteries. I put a note on the back of my Springfield temp now.
Posted on Nov 11, 2020
2 Related Answers
Steve
  • 3289 Answers
SOURCE: The outdoor temperature & hygrometer
Hi Walter,
I found this in the manual, simply pressing the RESET button won't start communication again. Try this:
Your main unit displays current, minimum, and
maximum temperature and humidity readings
collected by the remote sensor and main unit.
Outdoor data is collected and displayed every
40 seconds and indoor data is collected and
displayed every 10 seconds.
The red LED flashes whenever the sensor
transmits an RF signal to the receiver.
select sensor or use auto scan
• Press CHANNEL to switch between
sensors 1-3.
• To auto-scan between sensors, press and hold
CHANNEL for 2 seconds. Each sensor's data
will be displayed for 3 seconds. To end autoscan,
press CHANNEL or MEMORY.
• Press and hold CHANNEL and MEMORY
simultaneously to search for remote sensors.
resetting the system
The RESET buttons are located on the back of the
main unit and sensor. Use a pointed subject to
press RESET when you change the batteries and
whenever the system malfunctions.
Posted on Jul 13, 2011
Anonymous
SOURCE: I have a Springfield Precise
email me for the instructions manual.
[email protected]
Posted on Jan 12, 2011
I have a Springfield precise temp base station 433mhz wireless It has 11 buttons on front no number. It came with outside temp and weathervane parts. Would you have a manual for it? Thank you Jackie
Hi, Jackie.
Is it look like this ?
With Windspeed and 3 station temperature reading ?
If so, model number is 91751
Good luck with finding Manual.
I have paper manual with me, I can scan most useful pages for you (Buttons)
Apr 06, 2015 | Springfield Measuring Tools & Sensors
Springfield precise temp in out thermometer 91756
Return it to the manufacturer for warranty repair/replacement
Jul 23, 2014 | Taylor 91756 Wireless Thermometer With...
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
My indoor outdoor thermometer is only displaying the inside temperature and I lost the manual and can't remember how to reset it?
often removing the batteries in both units will reset. replace batteries in indoor unit firs, let it settle down then insert batteries into outdoor unit. There may be a button on outdoor unit to initialise the connection.
Alternatively you might find the manual here or get the instructions from their support.
http://www.orbyxelectronics.com/manuals.asp?choice1=3&choice2=14&hidPickIndex=2
Nov 04, 2009 | NexxTech (NOMR)
Measuring Tools & Sensors Logo
715 people viewed this question
Top Springfield Measuring Tools & Sensors Experts
Harrie
MODERATOR Canada
MODERATOR Canada
Are you a Springfield Measuring Tool and Sensor Expert? Answer questions, earn points and help others
