SOURCE: TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
SOURCE: Toshiba D-VR650KU can't "see" digital channels
On the Notification screen with Cable highlighted I found that left clicking on Cable gave a drop down menu with TV on it for selection. The manual says that while Cable is highlighted, use the up or down arrows to get TV to be an option and then select it and Yes and enter. Hope this helps. I have other problems with my monitor on Line Out, the screen oftens turns blue indicating low or no video using Line 1 or 2 inputs.
use a scart lead connected between your digital receiver to your tv
SOURCE: connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
hi my bush modle is btv183dvd\c i live in iran but i didnot buy this in iran well i listened that this modle has code ( if you kepp the negative switch volume on your tv & in that time push & keep the number 6 on controler ) you can see very much codes please dont change thoese
but i changed thoese and know i cant search for channel and it cant show that channel that befor time show that
please help me thank's
im armin
SOURCE: I need a manual to tune in a Alba LCD 19880HDF
Quite often with different TV, the built in tuners are different, so even though you may have been able to tune in automatically with one you can't with other tv's as there tuner isn't so good, you may want to look at getting a bigger aerial as the 1 you have may not get a strong enough signal for the tv tuner.
Testimonial: "thank you, will try that tonight"
