It wont update. I ge the message server address maintenance
SOURCE: get troubleshooting message
The encoderstrip which gives the head the position is out of place. You have to open the printer (cable, cover, screws..) and to put the encoder strip into the right place on top of the printhead. The encoderstrip is the foil which runs paralell to the drivebelt of printhead.
SOURCE: user's guide- trouble shooting and routine maintenance
printer will not print referring me to the trouble shooting and maintenance chapter in the manual which I can't find......I have a Brothers MFC-420cn CAN YOU HELP ME......
SOURCE: my 19 inch ge tv makes buzzing noise can it be
I've had this happen on a couple of TVs, it's always been from moisture getting into the back of the TV. I've been told by a few techs that the issue is beyond economical repair on older televisions.
SOURCE: "Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge
counter is already full. Please refer below for the instructions on troubleshooting
your machine.
1. To enter MAINTENANCE Mode: Press
MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the
following:
a. 8 then
press SET
b. 0 then
press SET
3. Using MONO START, just press it until
the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the
following:
a. 2 then
press SET
b. 7 then
press SET
a. 8 then
press SET
b. 3 then
press SET
This is to reset the purge
counter. Then press stop/exit
5. Using arrow up button look for the
following:
a. 0 then
press SET
b. 1 then
press SET (To reset unit)
a. 9 then
press SET
b. 9 then
press SET (To exit Maintenance mode)
