Question about American Standard Plumbing
American standard 2k-2h still leaks after replaceing sem and nut
Posted by dvid L on
Alcolu John
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Did you replace or reface the seat (the surface in the bottom of the faucet body where the stem's washer "seats" itself to shut off the flow of water? There are special tools for removing the old seats and installing new ones (available from professional plumbing suppliers), or you may be able to renew the seat's surface with a special tool called a seat surfacer.
Posted on Apr 13, 2018
4 Related Answers
Anonymous
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
Bill Johnson
  • 306 Answers
SOURCE: how to replace sprout seal kit in american standard faucet ?
just pull straight up,wiggle back and forth,the o-rings are holding it on .
Posted on Jul 15, 2009
Anonymous
  • 54 Answers
SOURCE: American Standard Hamilton Toilet Leaking
You have installed the parts improperly. You must have 3/8 of an inch slack in the chain from the flapper to the handle when flapper is closed.
Posted on Sep 26, 2009
packrat1948
Paul Beyer
  • 528 Answers
SOURCE: Are Standard plumbing products and
No
Whats the problem?
Posted on Feb 01, 2011
Can i add and subtract polynomials in this app or using numbers?
You can as long as the variables are the same. i.e. 2h + -7h is OK. 2h + -7k is not OK since the variables (letters) are not the same.
Nov 02, 2014 | Springer Polynomial and Rational Matrices
Double faucets cartridge replaced still drips
My best advice
is to believe everything you just experienced...
(Perhaps an UNSEEN flaw in the "MONOBLOCK")
Buy the replacement faucet... shop around:
I spotted it on eBay... (number not close...)
((but still reasonably priced)).
AMAZON
American Standard 1480 101 002 Seva Single Control Lavatory Faucet with...
Also went to eFaucets (but their site was stunned
(normally GOOD resource... ))
http://efaucets.com/
eBay (concierge... buyer protected... FREE ship'n)
American Standard 1480 150 002 Seva Monoblock Single Lever Handle Lavatory...
Save the old one (parts)and DIAGNOSE
it in your SPARE TIME...
Hope this helps
Carnac the Magnificent
Oct 19, 2017 | American Standard - Lavatory Faucet -...
How do I replace a spout O-ring on an American Standard Jasmine Hi-Flow Kitchen Faucet, 3821.831 or .834. I'm trying to get the spout assembly off to get access to replace. Thanks in advance!
The base of spout is like a nut unscrew then lift off spout install new o-rings be sure to use plumbers grease or vaseline to coat new o-ring ,reinstall as was disassembled that should take care of problem.You may need a strap wrench to remove spout base nut.
Jun 03, 2011 | American Standard Jasmine 3821.831.295...
I have an older American Standard kitchen faucet (installed around 1950) with a leaking spout. I have removed the spout, cleaned out all the old packing after removing the tempered steel split o-ring and...
If you have a payless cashways in your area they carry americanstd. faucets and plumbing fixtures.I think that some K-Mart and sears stores do also. Hope this helps you. Thanks
Dec 22, 2010 | American Standard 4275.550.002 ColonySoft...
I have an american standard shower knobs for cold and hot with a center control that directs to shower. Tub faucet leaks. How do I fix this?
Pull the knob off...usually the screw is behind a cover in the center of the knob...
Behind the knob you will find a nut that is the packing nut ... this is what keeps the water from running out around the stem...turn that nut clockwise a quarter to a half turn or until snug...
this iwll fix your leak...
heatman101
Aug 14, 2010 | Plumbing
I have an american standard single control faucet. I realized water was leaking down the pipes. When i turned of the hot water valve, water stopped leaking. How do i go about fixing this.
Chances are your supply line is leaking. One of three things (easy fixes).
1) There is a "packing nut" on the shut off which holds the handle on - this could be leaking (just tighten with pliers while open).
2) There is a nut directly above the shut off (3/8 inch) which goes directly to the faucet. Simply thighten this nut.
3) There is yet another nut above the last (very near the faucet). This is a 5/8 nut and you will most likely need a "crescent wrench" to tighten this as you cannot get pliers up there. You can purchase a crescent wrench at any hardware store for about 10 bucks. Good luck!
Dec 30, 2009 | American Standard Kitchen Faucet 6310 020...
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Leak in the faucet handle
Here is a link to the manual,Page 2 and 3 has the info you need.
Please take time to rate this a fixya
May 20, 2009 | American Standard 4175.200.002 Colony...
Mine leaks handle and cap (housing cartridge)
there should be a little cap covering a allen srew in the front or back of the handle it sometimes looks like the hot or cold sign or chrome pop that off and loosen the screw and pull off the handle there should be a nut loosen that and pull up the cartridge you might be able to find one at home depot be sure to turn the water supply off
May 20, 2009 | American Standard 2175.502.002 Colony Soft...
Replaced flaper as it was leaking in about 30 mi. Replaced and st
Hard to read you question. No sure what it is but if the flapper is still leaking it may be bcause most brand of fleappers do nto fit American Standard commodes correctly. Purchase a replacement made for American Standard only.
May 06, 2009 | American Standard Colony 2388.012.222...
Plumbing Logo
200 people viewed this question
Top American Standard Plumbing Experts
Bill Johnson
john h
Fahr Quad
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
