Cameras Logo
Question about Sony Cameras
You sent a 2.0 teleconverter and adaptor for Sony Nex mount. I have an a7Rii with an attached a-mount to e-mount adaptor. Do you have a teleconverter and adaptor for my e-mount camera?
Posted by Marietta Scheibe on
Tony Parsons
  • Sony Master
  • 6,402 Answers
We have not sent anything. Fixya does not supply goods or services, only free advice. Please contact the actual supplier of the goods - their details are probably on the invoice or shipping note.
Posted on Jan 21, 2018
4 Related Answers
Anonymous
  • 667 Answers
SOURCE: mounting a teleconverter on a minolta camera
AS you have found out, the Maxxum AF mount and the MD mounts are much different. They do make tele-converters that allow the use of MD (non-AF) lenses on a Maxxum series camera. You would still need another adapter to make the MD Tamron converter work,
Posted on Jan 08, 2008
Anonymous
  • 155 Answers
SOURCE: lens adaptor
The good news is that it is possible to get the camera to operate with the lens & adapter :-)
The bad news is that you'll only be able to use it in manual mode :-(
To get the camera(s) to actually fire, you will need to change some settings.
For the Maxxum 7:
Go to Custom settings (No.16) and change to 'Lock Off'.
For Maxxum 7D
Go to the settings menu (purple cog icon) and then to sub-menu 3. Change Shutter lock to Off.
With the camera set to Manual mode, you can still use the built-in meter. Half-press the shutter button and you will see a metering scale appear in the viewfinder. This will indicate whether the shutter/aperture setting you've selected will over/under-expose the image. Adjust your settings until the indicator bar is over the zero.
Hope this helps,
Matt.
PS. Even if you could somehow modify the adapter, the lens won't have the necessary electrical and mechanical coupling for the cameras to control it in an automatic mode.
Posted on Mar 05, 2008
Anonymous
  • 7191 Answers
SOURCE: Seeking instruction manual for(1) Sony
Hi Denis,
You can download and print the instruction manual for Sony NEX-5 in PDF format by clicking this link.
Also, please let me know the exact model number for the Sony full hd 1080 120gb handycam so that I can provide you with the specific manual.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Oct 07, 2010
Anonymous
SOURCE: Sony NEX-3 - I can't
Hi there, If you haven't already done so... Try connecting to a different USB port, or on a different computer. I noticed on my brothers computer, that when I use one USB port - doesn't work, but the other one does (probably something faulty inside on one of them). Also can try connecting using another different cord...
Hope you can get connected... ****.
Posted on Nov 26, 2010
tip
Upload Sony NEX-5 MTS to QuickTime H.264 MOV for YouTube Sony Alpha NEX-5 is one...
Sony Alpha NEX-5 is one of the interchangeable lens digital cameras, with all the components, bodies and lenses support the feature to tackle continuous autofocus and exposure adjustment while recording video. The Sony NEX-5 supports recoding 1920x1080 AVCHD video.
With the HD videos filmed by Sony NEX-5, you may want to upload them to your YouTube account for sharing with friends and families. However, YouTube does no support .mts files yet. One of the fast solutions is to convert .mts videos to QuickTime H.264 MOV with Mac Sony NEX-5 MTS to MOV converter. Aunsoft MTS/M2TS Converter for Mac is the recommended tool for you to share Sony NEX-5 videos.
Have a look at the steps below to upload MTS HD videos to YouTube on Mac OS X like Snow Leopard.
Step 1. Load Sony NEX-5 videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony NEX-5 MTS to MOV converter, and click the "Add" button to load .mts videos for conversion.
Step 2. Choose QuickTime H.264 MOV format.
Click the "Format" option, and choose HD Video > H.264 HD MOV(*.mov), and the Mac Sony MTS to MOV converter will transcode the HD MTS files to MOV for YouTube. As YouTube supports HD video in 1920x1080 and 1280x720, the default settings in the profile are OK for uploading.
Step 3. Convert Sony NEX-5 MTS to H.264 MOV for YouTube.
Click the convert button under the preview window, and the Mac Sony MTS to MOV converter starts converting 1080i MTS to HD MOV for uploading to YouTube.
After the conversion is finished, log in your YouTube account and browse the output QuickTime H.246 MOV for uploading to YouTube. The Mac Sony NEX-5 MTS to MOV converter also deinterlaces AVCHD videos. It is easy to share camera video on YouTube without interlacing problem for watching on computer. The converter also works with Sony HDR-XR500, HDR-CX110, Cyber-shot DSC-TX7 and other AVCHD cameras.
The NEX-5A with the 16mm lens sells for US$650, while the NEX-5K with the 18-55mm lens will sell for US$700.
on Jul 28, 2010 • Cell Phones
Where can I get a 2x converter for rear fit to pentaxZ-10 "?"
This camera uses KAF2 mount or earlier K mount teleconverters. Search "KAF2 teleconverter" on eBay and you'll see dozens of them ranging from $10-$20.
Hope that helps
BAX
Apr 24, 2014 • Photography
HOW TO PUT Fotodiox 49mm Filter Thread Macro Reverse Mount Adapter Ring for Sony E-series
The ring threads onto the front of any lens with a 49mm filter thread, just like a filter. The front of the lens then fits onto a camera body, effectively mounting the lens "backwards" or reversed. With most lenses, this allows the lens to focus very close, for close-up or "macro" photography.
2helpful
My sony nex 7 do not see the mounted lansbaby composer pro
The Lensbaby does not have any electronics to communicate with the camera. You need to set the camera to Manual exposure mode and shoot without any of the benefits of electronics (autofocus, aperture control, exposure metering, etc).
1helpful
Metz flash sony nex camera
Sony NEX 6 has an ATG/Sony's Multi-Interface-Shoe.
Let's hope the Metz 58AF-2 Flash is made for Sony/Minolta, which has an old Minolta's hotshoe.
Contact Sony for the adapter.
Or just buy the Promaster Sony Multi-Ineterface Shoe Adapter, it less than Sony's.
[email protected]
Just got a 2x teleconveter and need instructions for install and removal
Pretend the teleconverter is a camera, and mount a lens onto it. Then treat the lens and teleconverter as a single lens, and mount that onto the body. It effectively doubles the focal length, and robs you of two stops. Depending on the teleconverter and lens, you may or may not lose autofocus and metering capabilities.
Feb 04, 2010 • Photography
Tele converter option for Tamron 28-75mm f2.8
This is a lens for Sony/Minolta cameras. It is not compatible with the Nikon D90. Hence a Teleconverter for Nikon will not work on this lens to mount it to a Nikon D90.
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
