Question about Panasonic Car Audio & Video
Question RE: Radio Amp Can a JBL Model # 96379-A200 amp replace original equipment amp Panasonic 96370-A100. I assume the 100 and 200 refer to wattage. The wiring harness plugs appear to be the same.
Posted by Rodney Ellis on
5 Related Answers
v1k1ng
  • 6 Answers
SOURCE: radio conector problem
Try halfords they do a lot of car audio conectors.You give them the name of of the product your fitting and the car you want to fit it in.usually a universal plug is offered.plug it in your radio then into your loom and away you go.No additional wiring no mess.Usually costa around £7.Hope this helps.
Posted on Jun 27, 2008
Anonymous
SOURCE: need wiring diagram 94 jeep with infinity sys and amp
http://www.jeepforum.com/forum/showthread.php?t=507916
has the wire harness information for the amp. very hard to find great photos. the radio should have the sticker on the back telling you what the wires are designated for.
Posted on May 16, 2009
Anonymous
  • 655 Answers
SOURCE: i need to wiring diagram for a jbl 96370-2c500
Hello steve51383,
It appears that the specific model you referenced was installed as OEM equipment in Hyundai vehicles.
I couldn't find a 2c500 model number on JBL's website, although some of their OE models were listed. Most likely they left product support up to Hyundai.
You may be able to get a wiring diagram from Hyundai or perhaps a car forum like www.newtiburon.com may have one or more members who have experience with the product and may have the wiring information.
Other than those sources, your local Hyundai dealer could probably help, but I have no idea what the cost would be.
Hope this helps.
Posted on Aug 17, 2009
ironcrossaud
Iron Cross Audio
  • 281 Answers
SOURCE: Harman kardon radio does not have fader. HD Amp is
unit needs to be programed for the fader to go active at a dealer or by Iron Cross Audio
Posted on Feb 07, 2010
Libran Moreno
  • 126 Answers
SOURCE: I have a Clarion xmd3 radio that will not power
check to see if you have any grounding issues or if ground is present
Posted on Jun 12, 2010
How many input voltage do i need for my jbl creature ii.is it ac or dc?
JBL Creature needs a 18V, 3.5 Amp, AC power supply. JBL original power supply model is TA66180350-B2 made in China. In put power is 220-240V, 50 Hz-0.5 Amps. The AC supply is made to a dual rail supply inside the creature using a diode bridge.
Sep 08, 2014 | JBL CREATURE II Computer Speakers
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Have a PSW-D112 sub woofer that needs a new amp. Repair facility says original amp took a catastrophic power surge and it's toasted. JBL says repair parts not available. Please advise on source for...
Go to Parts Express and buy the Bash 300w digital subwoofer amp.It fits almost exact except it is one inch shorter.Just use mdf to fill the space and this amp will outperform the original.I have done this and it's not really difficult,pretty straight forward.
They usually sell for around $149,but they have sales often around $99.Good luck.
Oct 28, 2010 | JBL PSW-D110 Speaker
Does a Toshiba Equium A200 have a built in microphone?
Here are two different spec sheets for the A200-1V0 & A200-196. Neither one lists a "built-in mic" but both support external mics via 3/8 jack. Also there's always the possibility of using a USB mic.
A200-1V0
A200-196
Hope this helps, if so please comment, vote, etc.
Thank you.
Jun 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
When my jbl psw-d112 is on it will run just fine for a few min then it will sound like the speaker is blown. the green power light that is next to the vol level knob starts to turn red. What does this...
That model is known to have issues with the amps.Your problem is caused by a couple of components on the board shorting out.If you pull the amp out you will find on the large board behind the speaker terminal a couple of burned components.
The easiest fix is to buy a Bash 300w amp from Parts Express and replace the original amp.The Bash amp fits pretty well except that it is about an inch shorter.You can fill the hole with some mdf and have a sub that actually performs better than the original and with less heat build up as it is digital.Hope this helps,it's not complicated really.
May 01, 2010 | JBL PSW-D112 Speaker
I need to wiring diagram for a jbl 96370-2c500 so i can put it in my car
Hello steve51383,
Hope this helps.
Aug 17, 2009 | Car Audio & Video
No Audio
IT MAY BE A GOOD IDEA TO CHECK THE WIRES BEHIND THE HEAD UNIT AS THIS IS WHERE EVERYTHING IS POWERED FROM, MAYBE A LOOSE EARTH LEAD OR MAYBE A LOOSE POWER LEAD, SOMETHING SOUNDS LOOSE.
Jun 18, 2009 | JBL BP1200.1 Car Audio Amplifier
What does the "JBL" stand for wth an OEM auto stereo?
As for JBL is a band name.
http://www.jblproservice.com/
Hope this answers your question.
Mike
Mar 21, 2009 | Car Audio & Video
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL PSW-D112 Speaker fuse blow immediately after replaced
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Jun 27, 2008 | JBL PSW-D112 Speaker
Car Audio & Video Logo
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
