I have a Janome 900 CPX that I have had no issues with until now. Used yesterday but today the right needle keeps coming unthreaded. I have put in a new needle, rethreaded numberous times and tried different tension and differential feed settings. Tension is perfect and hem is beautiful starting out but part way through the needle just comes unthreaded. Not sure what else to try. Hoping you can help. Thanks
SOURCE: tension
Check your tension disks, with your presser foot up, and the tension dial on zero. Sometimes a piece of cotton breaks off between the tension disks and then prevents the disks to work properly. Also make sure when you thread the machine, the thread does go through the disks and over the take up lever. After you threaded the machine, before putting the thread through the eye of the needle, lower the presser foot and while pulling on the thread with your left hand, increase the tension with your right hand. Do it slowly and you should feel in difference in tension. If this is the case, your machine should work fine.
SOURCE: The serger is not sewing
The machine was threaded incorrectly at first, but after changing the needle I was threading it correctly. The problem ended up being the needle depth. When I inserted the new needle, I did not have pushed up into it's slot quite far enough. I pushed it up all the way and retightened the screw. Now it is serging like a dream!
SOURCE: can't get the bobbin thread to raise
i have a singer inspiration my needle is hitting the bobbin case and needle keeps on breaking not picking up the thread . how can i fix the bobbin case. help
SOURCE: keeps cutting the thread from inside the machine
Make sure all of your threads are in between the tension dials. Sounds that the machine isn't catching because of the tension. Good Luck
SOURCE: NEEDLE KEEPS COMING UNTHREADED WILL NOT CATCH IN FABRIC
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
