Question about Blaupunkt Televison & Video
Blaupunkt TV is completely black with no image but flashes red and blue
LED TV using double monitor
Posted by Joe Greenwood on
David Tickner
    Sergeant:
  • 159 Answers
I do not know this TV but my reaction would be to unplug any external monitors so its working just its own, then turn it off (by the mains) wait five minutes then turn on and see if anything has changed.
If not then see if you can get the menu up, if you can find its system reset/ restore to bring it back to when it was new, this will mean you will have to reset things but it might clear any other issues.
Should that fail then I suspect its graphic IC has failed which will be a new TV because modern sets are not worth repairing beyond about 3 years less so for the real cheap types, due to technology moving on which results in older models losing value very quickly.
Hope this helps..........
Posted on Jan 18, 2018
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Posted on Jul 31, 2006
Anonymous
  • 375 Answers
SOURCE: Screen Turns Red and then TV shuts off
you red crt is shorting out.tap the neck of the red crt lightly to try to remove the short.if no go also inspect the neck board.
Posted on Oct 24, 2007
Ecollier2012
Edward
  • 3459 Answers
SOURCE: getting "red" double image
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 09, 2009
Anonymous
SOURCE: Red LED lights
power supply shot ... sometimes x board or y board
Posted on Dec 09, 2009
Chi Chu
  • 8457 Answers
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
Posted on Jan 27, 2010
Samsung LED TV model no UA32D4000N colour becoming purple after running of 20 mints
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Mar 19, 2018 | Samsung Televison & Video
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
Vizio 55 inch TV "Vizio E550I-B2" is Darker on the left viewing side, replaced the Power Supply board. And the Screen is still dark on the left side. Any suggestions?
It is a common problem for this TV, it uses a Sharp LED display panel. The problem is the data buffer IC inside the panel ether shorted, or burned open.
Vizio offers a extended exchange warranty if you have the original sale slip.
For more information, you may contact Vizio directly.
Apr 24, 2017 | Vizio Televison & Video
How to solve led monitor double image problem ?
Double image or ghosting problems are often caused by a cheap cable from the computer to the monitor. Try borrowing one from another computer or someone you know, just to check if that's the problem. (as long as it's not the exact same brand of cable you're using)
Jul 26, 2016 | Computers & Internet
How to use tv as computer monitor
A lot will depend on what computer you have. If your computer has got an HDMI output then you can connect this port to the HDMI input of the TV using an HDMI cable. Then in windows control panel of computer you select Display properties and select the monitor port.
Aug 18, 2014 | Samsung 32" Class Full HD 1080p 60Hz...
How can i fix my hitachi ultravision it has green and double vision on top of screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 23, 2014 | Hitachi UltraVision CineForm 55VG825 55"...
Samsung monitor 2232bw plus backlight fade in black backgrounds scenes
Most common failures in these LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply C242 470uF 10V, C241 & C242 1000uF 16V, C261 & C319 680uF 35V failed as indicated in the attached picture, replace them at once.
If the power supply board is working then it is back light problem, first do a flash light test. If you can see the image in the flash light test, follow the steps how to test back light voltages: https://how-to-repair.org/repair/lg-tv-repair-manual-pdf/lg-led-tv-no-backlights-32ln5300-32ln5310-32ln5700-voltage-test-troub/2pyuXwNkBMA.html and follow the steps how to repair back light LEDs: https://www.youtube.com/watch?v=_poWTEihIJU Fix Led Backlights for TV or Monitor Lg Led Tv No Backlights 32ln5300 32ln5310 32ln5700 Voltage Test Troub Lg... Fix Led Backlights for TV or Monitor
samsung-2033sw-2233sw-ip-43135a-bn4400124s-power-board-dfydxumns33ohqc3bsmt22yf-3-0.jpg
Nov 07, 2013 | Samsung SyncMaster 2233BW 22" LCD Monitor
Can a vizio monitor be used with an apple G4 desktop computer
Oh wow guess I was proved wrong! But I read here that alot of people were having problems, my only concern is if the computer has a pc mode that can use hdmi or mini display port. If not you may have to mess with the settings to get a good picture.
g4 led
May 24, 2012 | Vizio E220VA 22 inches LED-backlit LCD LCD...
Can you use this tv as a computer moniter
sure why not? pretty sure any flat panel TV can be used as a monitor all you need is a double ended monitor cord as opposed to one that is part of a monitor even if you wanted to use an older crt type TV all it takes is the proper interface board.
Dec 21, 2009 | RCA L26WD23 TV
Televison & Video Logo
1,729 people viewed this question
Top Blaupunkt Televison & Video Experts
Marvin
Marvin
Vernon Taylor
Andrew Taylor
Andrew Taylor
Are you a Blaupunkt Televison and Video Expert? Answer questions, earn points and help others
