Question about Sony RDR-GX300 DVD Recorder
Sony RDR-GX300 DVD Recorder > cant progamme channels to record
Can play dvd's but when in easy setup doing channel search it cannot find any programs, setting time and date ok?
Posted by shortlegs on
Anonymous
    Problem Solver:
  • 11 Answers
Is the dvr burner hooked up to cable directly or is it coming from a cable box through video cable or again from coaxle cable?
Posted on Nov 24, 2007
Rdr-gx300 vhf/uhf to tv not working
Hello Cat napoli,
Try putting the TV on channel 3 or 4 and see it it works.
Dec 29, 2017 | Sony RDR-GX300 DVD Recorder
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
I have an rdr-gx380 recorder that wont play back some burned dvd movies why
i want buy for fixing my CCTV....
RDR GX380 have any problume to do this?
Mar 13, 2010 | Sony RDR-GX300 DVD Recorder
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
CANT FIGURE OUT HOW TO RECORD OFF AN 'AV' SETTING
The method is the same as for TV channels; select the input (i.e. view the desired channel), then press the record button. AV1 and AV2 usually are at the end of the channel list, and can be found by pressing the channel UP or DOWN buttons.
Aug 13, 2008 | Sony RDR-GX300 DVD Recorder
Dvd recorder
No, it is built in.However, AnyDVD software can correct that on a PC, and you can create a new copy from the original.
Jun 09, 2008 | Sony RDR-GX300 DVD Recorder
Can not change TV channel on DVD Recorder.
some dvd/vhs tuners do have this locked issue and since poor qc or qa on the manuf. part , they think since items are low cost anyways buy another one.
Mar 27, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Green screen on a LCD T.V.
if u can see other programs then the problem will be due to the signal fail the cable connecting may be faulty and it is very rare for a new player u check it with a new cable and change the pal and ntsc it may also make the picture correct
Jul 03, 2007 | Sony RDR-GX300 DVD Recorder
Sony RDR-GX300 DVD Recorder Logo
147 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
