Question about DISH Network Televison & Video
Can’t get dish network signal on element tv - DISH Network Televison & Video
Posted by Lon Cleveland on
Larry
  • DISH Network Master
  • 2,800 Answers
What input are you using?
Posted on Jan 18, 2018
5 Related Answers
Anonymous
  • 197 Answers
SOURCE: sharp tv dish network
that maybe the case..you could put a shielded barrier(copper coated poly) between them.sounds like it's a little too sensitive
Posted on Jun 20, 2008
Anonymous
  • 64 Answers
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Posted on Nov 25, 2008
Anonymous
SOURCE: no signal when hooking up to dish network.
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
Posted on Dec 12, 2008
Jim Franks
  • 374 Answers
SOURCE: Viore tv won't see dish network
I will assume this is a direct connect from the wall plate to the TV. With that said you need to run a scan on the set to lock in the channel the second TV is modulated to either 60 air or 73 cable usually. Go into the menu on the tv and select the auto channel search. Some sets scan both sides at once others require you to choose cable or off air. Once this is done you should find the signal.
Let me know if you need further assistance.
Thanks for using Fix Ya.
Posted on Dec 21, 2009
danbusa
Daniel Busa
  • 185 Answers
SOURCE: Need code for element tv to program dish network
Try this link it should give you the codes and instructions.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Daniel Busa
DISH Network Customer Service
Posted on Jan 19, 2011
It has "V1.43 Pace PR150BNM SysCode Loader" Pace. Across the top of blue screen, what's up?
Element Electronics blue screen no signal Questions ... - Fixya
www.fixya.com > Forum > Tags > blue screen no signal
Blue screen with ''component 2'' in a box shows. Then it goes black.There is also a humming coming from the tv. I have unplugged everything from the tv, and ...
element tv problem - YouTube
? 2:26
https://www.youtube.com/watch?v=2FnqRRcQzNs
Feb 17, 2010 - Uploaded by pacman552sd1
... is a vid im attaching to my email to custamer support to try and fix my bad tv. ... LG LCD TV REPAIR - NO PICTURESCREEN FIX REVIEW ...
Dish Network - My element TV is saying "no signal". ' Directly
Jan 09, 2016 | Element Televison & Video
Need code for element tv to program dish network remote
Daniel Busa
Dec 03, 2010 | Element Electronics FLX-2610 26 in. LCD...
Dish remote
cathyw43
I have provided instructions on how to program your DISH remote to your TV. I have also provided a link with the codes for TV manufacturers. I hope this helps.
Program remote, step 6:
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
May 29, 2010 | DISH Network IR Remote Control
Dish network remote to run RCA DVD player
I had rca remote that did not recieve ir signals but rf signals instead. Check online with rca or in owners manual for what type of signal factory remote sends. The dvd player I had was 5 dvd and that was the case. Dish might have an option like direct tv where you can program rf signals as well. Call dish network support or look online
Apr 25, 2010 | DISH Network IR Remote Control
You're closed captioning is all jumbled up on Seattle's KIRO TV from my DISH network. The cc works fine on all other channels. Dish says it's a network problem. Any response?
The CC is provided to DISH (and all cable/satellite companies) by the network that creates the programming. Usually, live TV (like news, sports, etc) is the most jumbled because of the time it takes someone to transpose what is being spoken as it is being spoken. If this is a network that is available OTA (via antenna), verify that the issue is not happening when you are receiving the signal from somewhere other than DISH (if you cannot receive an OTA signal, try at a buddy's house that uses another cable provider). If the problem occurs via OTA or other providers, contact KIRO to have them improve their CC service. If it only happens when viewed with DISH, contact DISH, who will then resolve the issue with KIRO (usually a lag time in signal transmission from the provider).
Feb 11, 2010 | Televison & Video
Dish network remote with a element tv
Nov 23, 2008 | DISH Network IR Remote Control
HD TV
In order to receive HD signals, you will need an HD receiver from Dish Network. You can buy an HD antenna from pretty much any store that sells TV stuff (Target, Wal*Mart, BestBuy, etc) which will allow you to receive over the air HD signals. But in order to get your satellite channels in HD, you will need an HD receiver from Dish Network.
Jun 09, 2008 | Televison & Video
Elements TV need code
the new element television I purchased listed codes in the manual (on the back or as an insert) for dish network. Worked on mine.
Apr 11, 2008 | Televison & Video
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
Televison & Video Logo
41 people viewed this question
Top DISH Network Televison & Video Experts
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
