Question about Ricoh Office Equipment & Supplies
I have ricoh aficio printer 1060 - windows 7-64bit. I can not define the scanner. twain
My printer is usb outlet.
Posted by qasim ab momani on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
Only network twain drivers and only network scanner. Not possible to be used as scanner via usb.
Posted on Jun 26, 2018
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: problem in scanner when scan
Try adding the scanner's IP address in the scnhosts file in the TWAIN folder. Format is similar to the windows hosts file. You'll see a commented out sample entry, just modify that to suit your needs.
This may or may not work for you; we had it working under this configuration but then it stopped for no apparent reason. also note that scanrouter isn't supported under vista. Only advice I've been given so far is to revert to sending scans via SMTP - not ideal!
Posted on Jul 22, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 11, 2008
Anonymous
  • 1073 Answers
SOURCE: I NEED Ricoh Aficio 1018 Printer/COPIER AND SCANNER DRIVER
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/x1015_18/x1015_18en.htm
There you go M8!
Just selcet your OS and download the files you need
Good luck to you
If you find my answer helpfull, dont forget to vote
Posted on Dec 15, 2008
Anonymous
  • 162 Answers
SOURCE: Aficio 1060 - SC550
• Web end (requires replacement) fusing unit
• Web end sensor defective
Note: After replacing the web with a new
one, reset SP1902 001 to 0 to
release SC550.
Posted on Sep 02, 2009
Chris Larocque
  • 367 Answers
SOURCE: Ricoh Printer/Scanner is giving an
When you say other users can access it fine, are you meaning on other computers, or other user accounts on the same computer? If it is other computers that it works fine on, what are their OS versions? XP, Vista, Win 7?
Try logging into the XP system as administrator and scan from there. I have heard of user permissions preventing access. Is the issue only with the scanning, and actual print jobs go thru ok? If you can not print as well, you may have some networking issues / permissions to work thru.
Chris
Posted on Jul 12, 2011
2answers
I am trying to setup the 1515MF for network scanning. The manual tells me to go to scanner and select Twain on. But when I go to scanner features and then scan settings, my only choice is "default...
First download the twain drivers from Ricoh website or if you have cd down load it from it. Then from there when you go to scan should give you selection option for it.
1helpful
I have my Ricoh Aficio MP 2000 connected to my computer via USB but my computer does not recognize the scanner. I can however print from my computer to the Ricoh. I tried installing the TWAIN driver,...
I have the same problem. I use the USB, my client is far far away from me, and is better for me install the Ricoh using the USB. But the scanner don't work.
Maybe the only way is using a ethernet cable, but i dont want to drive so far... :(
1helpful
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
I have a Ricoh Aficio 1515 MF. I cannot get my Windows XP Pro to recognize the scanner, and I downloaded the Twain driver from the Ricoh site. Help! I want to scan into Adobe Acrobat.
Does the machine show up on your computer - you can print?
do you see it in scanners and cameras in start - control panel -> scanners and cameras? what is the status shown there on the properties?
5helpful
TWAIN DRIVER VER 3 12320 Impossible find the scanner
"twain" is not accessed from the machine itself, but rather a photo editing program (or similar) on your computer.
Usually via "file", "import"...etc.
5helpful
3answers
Problem in scanner when scan
2helpful
2answers
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
