Question about JVC Audio Players & Recorders
My jvc dvd home theater model A35 is displaying error press power bottom off /on to rest
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: Home theater won't start playing DVD
If a disc will not spin, A- the laser may not be focusing on the disc, as it must do this before it will spin and read the TOC. ( table of contents) B- you could have a fault in the spindle motor circuit or the motor could be bad. You will need to find an authorized servicer if you do not understand solid state repairs. Good Luck PS please dont forget to rate this.
Posted on Oct 14, 2006
Anonymous
SOURCE: DVD MALFUNCTION [MODEL PIONEER XV-DV131 (DVD/CD HOME THEATER]
I have the same problem with my XV-DV333. Search on inet and this came up: "... Pick Out One Of These! But I am unable to select any region using the remote control or the buttons on the player. What do I do? You need to get a Pioneer Service Remote. When you have it you should press: [ESC] [A.MON] [Numbers], where [Numbers] correspond to the region number you want to set. Be aware that you can only set this once, if you set the wrong region number for your area, there is no turning back. " WTF! Am I supposed to get a service remote to get this thing working again. I haven't done anything and it worked before:/
Posted on Sep 08, 2007
Anonymous
SOURCE: PL-D2000 DVD Home theater System
Turn on the player for about an hour untill it heats up and then play the disc. Most probably it will work. If not you will have to replace the lens or card.
Posted on Dec 30, 2007
Priya darshan
  • 3422 Answers
SOURCE: unlock a panasonic dvd home theater to region 2
You can buy the codes from HERE or HERE
Goodluck..
Posted on Mar 19, 2008
Anonymous
  • 5 Answers
SOURCE: not getting any power
Probably a blown fuse. If you have a warranty or can return it do that, if not unplug it, open it up and there should be a 250 volt glass type fuse. pull it out and make sure it is blown. If it is replace it at radio shack. If it isnt check for loose wires around the power cable and the transformer.
Posted on Feb 27, 2010
If press eject button,it's showing LOCKED.what can i do?
You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Jan 21, 2015 | home Audio Players & Recorders
Home theater system jvc th-d60
have you used a different connector cable?
if not try that first
Aug 22, 2008 | JVC THD-50 System
The DVD player seems to immediately attempt DVD mode upon powering on, despite no disc being present. The display shows "ERROR, PRESS POWER OFF/ON TO RESTART" and no other action is possible...
You have an internal mechanical switch/sensor which failed and will need replacement.The reason it is giving this message because the sensor might have been stuck in a position when it was damaged. And also along with it some parts(semiconductors and capacitors needs to replaced too)need some checking too.
Jan 30, 2011 | JVC TH-A35 System
TROUBLE SHOOTING JVC DVD PLAYER DOES NOT SHOW COLOR PICTURE
Press and hole Scan Mode button for 2 seconds, Y/C will show in front display, use > to change to RGB then press OK.
Feb 25, 2009 | JVC TH-S11 Theater System
Sub won't power up
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Nov 16, 2008 | JVC TH-A10 System
Unlock code for jvc dvd
hi if you can help me i have a dvd jvc th-a35 and it wont play all the dvds what is the number or how i can unlock to play all dvds
Nov 25, 2007 | JVC TH-A35 System
TH-A35 receiver
You can't get 5.1 sound from a MP3 source !!! You get a 5.1 sound only from a good STEREO (analog) source or from a REAL 5.1 DVD audio track. Also check your "Autosurrond" setting on the remote-control.
Sep 14, 2007 | JVC TH-A35 System
Error message upon powering on
Unplug it for 10 seconds then plug it in again
Apr 23, 2007 | JVC TH-A35 System
138 people viewed this question
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
