Question about Kodak Photography
I lost my digital pictures except on a Kodak D725 picture frame. I cannot get my computer to recognize it. Is there a way to hack it and get the pics copied?
Posted by Erik Lingenfelter on
Tony Parsons
  • Kodak Master
  • 6,280 Answers
Just reload the pictures from your backup
Posted on Jan 17, 2018
5 Related Answers
Snibbo
SOURCE: Insignia digital photo frame won't recognize some .jpgs
When you save in Photoshop make sure you select "Baseline ("Standard") on the JPEG options when you save. That should fix the problem for you. It did the trick for My Kodak SV710 digital frame which wasn't displaying images I had edited in photoshop.
Posted on Apr 03, 2008
Anonymous
  • 76 Answers
SOURCE: copying pictures from computer to memory card
vista is main problem are you viewing the picture before you move them vista has problem if u open it 1st before coping moving etc etc it does what u mentiond b4 either shut the program u are using to view with down before u transfer them
Posted on Dec 02, 2008
Anonymous
  • 75 Answers
SOURCE: how do I transfer pics from my computer to digital frame sv811
Connect the frame to you computer via the USB cable. Your computer should see the frame as a removeable storage device (new drive letter) if there's memory on the frame to store images. If not, then get a cheap memory card or USB key for $20 and put the images there.
Posted on Jan 11, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: the kodak easy share digital picture frame won't show my pictures
Pls. check if there is any reaction when pressing the buttons onto the frame.
Check the batt within the remote.
Reset the frame.
If all fails:
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Oct 15, 2009
Anonymous
  • 47 Answers
SOURCE: I can't transfer pictures from
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Posted on Jan 05, 2010
Do not know how to transsfer pic fromcomputer to the Kodak pic frame
On one side of the frame there should be memory card slots and a usb slot.
two ways to do it, take the memory card from the camera and put it in the frame.
Or down load the camera to tyour computer and then with a usb cable upload the picture fram with the pictures you want
Or from your computer load a memory card and then stick it in the frame
Feb 20, 2010 | Kodak EasyShare SV811 (8858946) Digital...
I have a kodak easy share photo frame and don't know how to transfer pictures from my computer to my photo frame
Make sure you have installed the Kodak digital display Software then you can just drag and drop the pic to your pc or vice versa
Dec 24, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
How many pictures can the Kodak EasyShare SV811 hold at one time? I tried uploading around 30 picutres from my computer to my digital picture frame and only 17 of them uploaded. Did I try uploading too...
SV811 doesn't have a large enough internal memory thats why the picture capacity depends on the inserted SD card or if you transferre pics directly from the computer to display simultanously.
The frame should display as many as on the SD card.
Nov 30, 2009 | Kodak EasyShare SV811 (8858946) Digital...
How do I load pictures from the Kodak Gallery into my Kodak 811 frame?
You can use an SD card. Put card in pc, put pics on the pics file on card, then put card in the frame.
Nov 15, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Digital picture frame
Have you installed the EasyShare software on the computer?
Does it work when inserting the SD card into the frame directly?
You must connect the frame with the cable before the frame will be able to find the computer.
Contact KODAK:
Oct 26, 2009 | Kodak EasyShare SV-710 (8370181) Digital...
I dont have software for digital pic frame and dont know how to get pics from comp. to pic frame and i do not want to use my only memory card for pics on frame what do i do please help???
You are able top download Kodak Software on www.kodak.com/go/downloads and follow the prompts, however when connecting your frame it should show as several drives and one of those will open, the rest will give an error when trying to open. You are able to simply drag your pictures into this drive and it will display on the frame. There is no need to install the software.
Kodak EasyShare SV811 won't read SD / HD card
Compatible Card-Slots : SD/MMC; xD; CF;Memory Stick; Microdrive; USB
You might have too much data on the SD card. Try with less pics onto the card.
Contact KODAK:
Jun 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
My kodak ev1011 pic frame stopped working
You may try the online troubleshooting guide at www.kodak.com/go/itg and if it does not resolve the issue at the end of the guide you can fill out a form to send the frame for repair and also just an FYI the frame is warranty for one year and you must a copy of your receipt before sending the frame.
Jan 08, 2009 | Kodak EasyShare EX1011 Digital Picture...
Kodak easy share SV 811
I had the same problem. I use kodak easyshare software and load my pics on to that. Then put all the pics you want in the picture tray. Have your frame plugged into the computer with your usb cord. Then go up to File menu and drop down to "copy to". On my computer it is Folder "E" which is the drive the frame is connected to. Then pick from the Resize drop down menu " best for picture frame', then click copy. You will see the program loading all the pics to E drive. When done, unplug usb cord and you will see it loading on your pic frame. As easy as this is to do, I found it frustrating as well, but when it works, it is easy. Hope this helps
Aug 04, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Photography Logo
531 people viewed this question
Top Kodak Photography Experts
Davit Mamyan
Davit Mamyan
Muntejaya Ginting
Muntejaya Ginting
Harrie
Are you a Kodak Photography Expert? Answer questions, earn points and help others
