Question about Telefunken Tablets & eReaders
I can't update apps always there is no space on my Telefunken tablet?
Posted by Ernestina Lekhula on
Brian Acker
    New Friend:
    Problem Solver:
  • 12 Answers
You need to purchase a mini sd card to increase storage space. Transfer what apps you can to the card it will free up space on the tablet .
Posted on Jan 17, 2018
2 Related Answers
De Engineer
Les Davis
  • 247 Answers
SOURCE: how do i fix my pioneer tablet after reset that left it saying 0.00 space & 0.00 available & wont let me reinstall apps?
Remove apps & clean out memory space. Then download and reinstall. Or you may be able to add a larger external memory card.
Posted on Jun 05, 2014
t_w_miller_5
Tom M
  • 90 Answers
SOURCE: This tablet has 2 lots of memory,one called endeavour which has 4.83gb,and one called internal which has 142mb free.I want to update a few apps but it tells ,e I haven't got enough room! How can I upd
not exactly sure - but some tablets designate internal stg for the operating system and built-in apps and data such as address book or contacts, the settings app, etc. the endeavor stg may be the remaining available for your apps, data and media. Some updaters require extra working room to update an app - look in your settings and see if you set a default location for the apps and media you install. Another thing you can try is to delete the app and then reinstall it from the play store, the reinstall should grab the latest version. It also looks like you can add memory via SD card - probably a micro SD - 16gb is fairly inexpensive. Insert the card then mount it - look in your settings to see if you can set it as your default location or if it is offered as a choice when attempt to install an app. Some operating systems only allow media such as music, photos and videos to be stored on SD card memory - if possible, do a google search for your tablet model to find a manual.
Posted on Dec 10, 2014
Which apps can I remove without causing other apps to fail?
U can delete everything. U can delete widgets what u dont need. Or a calculator. try to delete some messages what u dont want to have. or some pictures what u dont need. Try something of theese
Dec 23, 2017 | Tablets & eReaders
Can't update any apps saying insufficient space even though it says I have plenty when I look at storage
go to settings>apps, select playstore, click clear data, restart your phone. This should do it.
Feb 09, 2016 | Tablets & eReaders
How can I find an old Hulu app?
Hi Deborah,
Hulu on the App Store
The link above will take you to the app in iTunes or App Store. If you receive an error stating you cannot download because you need to update, that may be your only option. By the model listed above I'm thinking your tablet is very new so you should have little trouble updating your iPad.
I will leave a link below describing how to update your iPad (link takes you to Apple Help).
Update the iOS software on your iPhone iPad and iPod touch
I hope this find you well,
Niall
Nov 19, 2015 | Apple iPad Air 9.7" 16 GB Wi-Fi Space Gray...
Cant get into kurio app store it keeps saying it needs an update but when I do the update it says storage space is running out and wont do the update
Not sure about your tablet, but generally if you delete an app or two and delete any cache that is stored you will be amazed how much space is freed up along with the benefit of it running faster.
Jul 21, 2015 | Kurio 7S Tablet
Hasn't saved anything to the memory card because his tablet won't allow him to .. It keeps saying not enough space it's a 8GB memory card
The internal memory cards of some Android devices are partitioned for app storage and installation. Some of them have partitions that are quite small such as one Gigabyte or smaller. The remainder of the storage cannot be used for apps.
If it keeps saying not enough memory space then chances are the app partition is full. The only way to free up some space is to uninstall some apps that are stored there but not being used. You can see which apps can be uninstalled in Settings > Apps and look at them one by one to see if an uninstall option is listed. Simply click *uninstall* to remove them from the app storage partition. This will free up some extra space for some new apps or for updates to older apps you still like and use.
Also some of the apps might show an option to move them to an external SD card (if your device has a slot for one and if an SD card in inserted therein). Do move any and all to the external SD card of you have that option as that will also free up that space from the internal SD card.
May 11, 2015 | Tablets & eReaders
It wont reconize half my memory so it wont let me download apps
It has very limited memory allocated for apps. It only amounts to about 661 megabytes. The entire SD card shows about 5.5 gigabytes most of which will probably be available for whatever but not for apps. Apps can only be written to the small app partition.
The unfortunate reality is if you allow automatic updates from the Google Store to update the native apps, there will NOT be enough room for them all and you will get a *no more space available* error message. So, turn off automatic updates in Settings in the Store ASAP! If you install an external microSD card in the slot in the back you might be able to move some of your apps to it using the Apps function in Settings on your tablet. This will free us some extra space on the built-in SD card. But, unfortunately, the native apps can't be moved. But, some can be disabled and some you can delete the data and the cache. But, don't delete the data on the ones you use or all your mail, accounts etc will go away and you'll just have to set it up and download mail again.
Feb 18, 2015 | DOUBLE POWER TECHNOLOGY Nobis NB09 9" 8 GB...
Facebook login problems
Have you tried to hard reset the device? To do this just press and hold the power and home button and the same time until you see the screen go black and the apple logo appear , now let go of both buttons, allow the tablet to start up. Try the facebook app again, does the problem persist? If the problem still persists, check to see how much space you have on the tablet, sometimes the limited amount of space on the device can prevent an app from functioning correctly. If you find there is not very much space remove several items, to create more storage space, then attempt to use the Facebook app again, does the problem still persist? If so, check the App Store to see if there is an update for the facebook app, if you find one under updates, install it, try to run the App again. I hope something here has helped you resolve your issue.
Sep 02, 2014 | Apple iPad 32 GB WiFi Tablet PC
Cannot download apps
tablet cannot download apps
Mar 05, 2014 | Craig CMP741d Tablet
My tablet will not turn on nor when it did it would shut down if I wanted to load apps
try to update the firmware from software update. also make sure that there is space to download and install apps. regularly clean your mobile and clear browsing data and call history
Oct 01, 2013 | Samsung Galaxy Tab Tablet PC
Tablets & eReaders Logo
99 people viewed this question
Top Telefunken Tablets & eReaders Experts
Marvin
Marvin
NOEL
NOEL
ray gallant
Are you a Telefunken Tablet and eReader Expert? Answer questions, earn points and help others
