larry Leffler II Posted on Jan 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 6 cd changer in my 2005 chysler Pacifica that stopped playing. Shows error message no cd.
The CD changer skips to the next player and says same thing on all 6. Audio outlet for DVD player won't play either. Used a CD cleaner and still won't play
Joe Ball
Level 3:
Master:
  • Master 591 Answers
  • Posted on Jan 17, 2018
Joe Ball
Master
Level 3:
Master:
Answers
591
Questions
Helped
165610
Points
1736
My experience with CD/DVD players has been, unfortunately, that when the trays stop opening and/or closing, or when error messages start regularly, it's history. Hope yours turns out differently, but I wouldn't count on it. It will cost you as much or more to fix it than to replace it. if you live near a large junkyard you might try to retrieve one there, but the fact that your car is 13 yrs. old will make that tougher.
5 Related Answers
Anonymous
  • 81 Answers
  • Posted on Dec 15, 2006
SOURCE: DVD S1000 video player
A new Laser pick up will fix your problem expencsive repair
petraman7
Scott Frye
  • 1175 Answers
  • Posted on Feb 24, 2008
SOURCE: cd player skipping
The DVD transport rides on chrome rails. These get dust and stuff on them and wont allow the optics to track.
If you dare, open the unit UNPLUGGED from the AC.
See if you can get at those rails easily. clean with WD40 on a swab. clean with a new swab . then a couple drops of mystery oil on a swab and run down the rails over and under.
You must be VERY gentle if you clean the lens with isopropyl
agrundy
  • 25 Answers
  • Posted on Mar 19, 2009
SOURCE: 2003 audi a6 cd player error 2
HI,THE REASON YOU ARE GETTING AN ERROR MESSAGE IS BECAUSE THE MECHANISM IS FAULTY,YOU WILL HAVE TO HAVE IT REPAIRED,ANDY
Anonymous
  • 30 Answers
  • Posted on Jul 27, 2009
SOURCE: Pioneer PD-F100 Constantly Skips to Next CD
the problem is not the laser, but the cable that connects the laser to cd board, it is cracked..and will break connection when moved out from its home position, i have replaced a lot of cabes for this model..i know it well
Anonymous
  • 3 Answers
  • Posted on Oct 03, 2009
SOURCE: warning on screen when you load dvd
the break wire needs to be grounded
4helpful
2answers
Altezza cd stacker error 3 with 6 cd's jammed inside
hey my toyota altezza cd player (changer) it keeps skipping and sometimes wont read the cd a gives me an error message. doesthe lens need to be replaced?
6-cd changer says error 3 and won't eject CDs
hi i recently bought a lexus ls400 and it the trunk it has a ten disc cd changer by the steering wheel in the car is this little black box that keeps reading E-99 evertime i press play on this odd little box that is the control device to make the cd's play i've put the cd 's in the changer upside down right side up testing it and still the little black cd player play button/disc change button keeps saying E-99 my question is, is it a fuse or is this cd player thing near the stearing wheel just a peiece of garbage please contact me at [email protected] if you have any idea why this is doing this because i can't play any cd's theres no cd player where the cd/tape decks usually are in cars in the middle above the column shift. it would mean the world to me if you could help me out with any information as to why this brand new sony ten disc cd changer is giving issues to the cd player thing next to the stearing wheel on the right it's kind of hidden but it just won't stop saying e-99 no matter how brand new a cd i put in the changer thank you your friend john bunce
4helpful
1helpful
2005 350Z 6 disc changer / error message
Use a Laser Lens Cleaner. Run it thru the player a couple times. Use one that has fluid with it, you can find them at any electronics retailer for 15-20. If it still has the same problem, the only thing to do is send it for repair, they will replace the transport. Average cost of 125-175 on a changer. Hope this helps
2answers
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
2answers
Error Message
sounds like the lens is dirty -try this out you kow them cans of stuff they use to clean keyboards with its like filtered air or something -try to blow out the guts of the cd changer with one of them cans and maybe it will help with functionality do the same with the cartridge emtied out and then run a cd lens cleaner disc and see if that does the trick-
2answers
RS2635 5 disk changer skipping
your cdplayer is probably at intro
Player only plays first 3 tracks on CD and then stops
the emitting diode is not shiffting right..it might need some cleaning of its track..open it and check it out. good luck
Top The Audio Players & Recorders Experts
vince
Paul Carew
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
