Question about Power Computers & Internet
I have a ComfortZone Quartz Infrared Heater Model CZ-1500P. I just noticed the plug was too hot to hang on to. Any idea what may be causing this?
The unit is still working great and I hate to get rid of it. I tried a couple different power outlets with same result.
Bill Boyd
    Top Expert:
  • Power Master
  • 53,816 Answers
Indicates that the unit is drawing more current than the plug and socket is capable of carrying( faulty unit)
10 amp plug carrying 12-14 amps that the 15 amp circuit breaker is not tripping on
first point---- hot plugs are indication of an imminent fire in the wiring and equipment
get in an electrician to test the unit and the house wiring for problems
Posted on Jan 16, 2018
1 Related Answer
Anonymous
SOURCE: Comfortzone heater displaying error message doFL.
According to the call line, hold down the up, down and enter buttons all at the same time and it should clear it. I took mine back and had it replaced so I never had a chance to try this.
Posted on Nov 19, 2010
Where in the thermostat in a CZ 1500P quartz infrared heater?
they usually have a thermal switch inside to regulate temp.
Oct 28, 2017 | Heating & Cooling
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
I have the Comfortzone Infrared heater. The heating unit will not kick on. It tries to but then a code comes up that looks like AOS or AO5.
sounds like the outlet is not enough power for the heater. Remember with an electric heater youre dealing with watts and amps, It should be plugged into its own dedicated service for proper operating.
Mar 04, 2011 | Heating & Cooling
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Jan 18, 2011 | Comfort Zone Heating & Cooling
Dec 29, 2009 | Heating & Cooling
Need Marvin quartz tubes
Marvin Replacement elements are available from Quartz Infrared Inc for $17.95. You can order them directly here:
http://www.quartzinfrared.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=Marvin
Dec 12, 2009 | Marvin 2060 Compact Heater
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
Computers & Internet Logo
35 people viewed this question
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
